Hi Guys,
Looking for a design for a demagnetizer coil.
It's inner dimensions need to be 6 Inch x 12 Inch (rectangular)
It will be used to demagnetize work pieces that have been subjected to the magnetic chuck of a surface grinder, such as car cylinder heads.
To use it I will have the coil stationary, and the head will be placed on a table mounted on v-wheels which in turn will run on tracks, thus the work will travel thro the coil.
Voltage will be 240v AC. And I anticipate a consumption of of approx. 10 amps.
I've made up the metal work including the coil former, which is made from aluminium channel.
Obviously, the field within the coil would need to be pretty intense, so the ampere/turns ratio would need to be pretty high but it would be only short time rated.
I would appreciate any ideas, thoughts on the matter.
Thanks & regards,
Norm.
