Previous in Forum: Generator Trouble Shooting   Next in Forum: Bugatti Automobile
22 comments
Water Pressure
08/01/2014 12:18 PM
I need to find out how many PSI it would take to drive a 3/4" stream of water. I have to reach 125ft. I can put as much pressure as is needed. I just need to know how much pressure.
FYI The 3/4" tube through which the water is to flow is 24" long and a 3/4" ID.
I took physics in high school but can't figure this one out.
A hand without an arm is a useless tool
Good Answers: 25
Re: Water Pressure
08/01/2014 12:28 PM
125' vertical?
Troy
Re: Water Pressure
08/01/2014 1:00 PM
Horizontal. Using for fire suppression.
Good Answers: 25
Re: Water Pressure
08/01/2014 2:17 PM
If you want to reach 125' maximum, I would estimate that you would need about 90 feet to the breakover point which equates to about 90 feet of head or about 40 psi as the water leaves the nozzle.
You will have to calculate (or measure) friction loss in your hose and nozzle and add roughly 40 psi.
Troy
Re: Water Pressure
08/02/2014 10:20 AM
I don't think so. Once the water leaves the nozzle, there is nothing to push it any further except inertia. Remember, it's not confined inside the pipe any longer.
At that point it starts to lose energy and slow down and spread out.
It's much more complex than that.
Good Answers: 25
Re: Water Pressure
08/04/2014 10:28 AM
Yep, good point, I should have thought that through more before I posted.
Troy
Re: Water Pressure
08/01/2014 12:56 PM
Is all 125 ft is a rise in elevation that's one thing. If the 125 ft travel length is down a 100 ft by -25 ft slope of a ramp then gravity by a stream or siphon will work fine. Then there are the questions of desired end point pressure, flow rate, flow restrictions, etc.
Here's a big hint for you, the density of water at 70°F is 62.31 lb/ft^3. This should be enough information to get you started.
Re: Water Pressure
08/01/2014 1:04 PM
I should have put what I am going to use it for in the question.. I am going to use it for fire suppression. To cool landscape to below the flash point to keep a forest fire from burning down my cabin.
Re: Water Pressure
08/01/2014 2:12 PM
I used to live in a hilly/canyon area of Calif. you cant beat this, but wind blows right over it
Re: Water Pressure
08/01/2014 4:07 PM
I guess you need an answer pretty quick then.
Re: Water Pressure
08/01/2014 1:26 PM
You need to know the GPM at pressure....I would guesstimate ~175 GPM at ~50 psi....You can have a pressure of 70 psi, and when you open the valve it drops to 0 with a flow of 5 GPM....For a pump to maintain pressure at flow it should be rated at about twice the GPM you need...the nozzle design is also very important...You might want to search this site for info, as we have had numerous discussions on this subject.....
http://www.tomsriverfire.com/fire_academy/pdf/basic%20pump%20manual%20feb09.pdf
Re: Water Pressure
08/01/2014 6:27 PM
Just for grins, go turn on your water hose. Most residential water is supplied at around 50 PSI and on a good day you can shoot a 3/4 inch stream out of a 50 foot hose about 8 feet.
Next, fill a 5 gallon bucket with that hose and see how long that takes.
You're going to need a lot of water to supply that stream. Forget the pump for a minute ask yourself if you even have the water for this. If you can't pull from at least a 4 inch supply you may have issues with pump starvation.
Then, there's the electrical service needed for a motor to drive that pump.
Pumping Water - Horsepower Requirements
You may be better off using a sprinkler system than a deluge gun.
Have you asked your insurance company for help designing a system?
I'm not trying to discourage you. Many items you have there are surly irreplaceable.
Good luck.
Re: Water Pressure
08/01/2014 8:30 PM
Thanks for your concerns. I get about 15 feet from my garden hose at full city pressure. The water supply is a 5000 gallon tank and the pump is driven by a gasoline engine.
Re: Water Pressure
08/02/2014 1:18 AM
I hate it when I'm so negative.
5,000 gallons of water will buy you maybe a half hour. An hour if you can limit the flow to 75 GPM. Then you're out of water, unless you have some way to replenish the tank.
Rethink your approach and how to protect the property.
Re: Water Pressure
08/02/2014 10:07 AM
Sounds like a good excuse to install a swimming pool!
Re: Water Pressure
08/02/2014 7:47 AM
I would surely be surly also if some wanted to replace me.
Re: Water Pressure
08/01/2014 10:39 PM
TO be honest if it was me I would be planning around a system that can supply at least 150 PSI at the nozzle with a flow rate of 50 GPM or better.
I have a 3 HP multistage electric pump I used to use for watering my lawn on the dry years and if I am recalling things correctly it could maintain about 70 PSI at somewhere around 25 GPM through 10 or so feet of half inch line resulting in a solid stream that could reach about 50 - 70 feet.
Based on that I would be shooting for a minimum of at least double that PSI at double the flow rate for a base line.
Re: Water Pressure
08/01/2014 11:12 PM
The people who have managed to save their homes in the path of forest fires or big suburban fires like the Oakland California Hills fire had swimming pools for a supply and big gasoline driven pumps. A 2" fire hose and nozzle would be a great addition to the kit assuming you can hold the thing down under pressure. But at least a 1" hose. No standard garden hose or house plumbing is going to supply enough volume, no matter the pressure.
Personally, I'd cut the underbrush and burnable items away from the cabin by about 100 feet as well. If you have combustible objects close to the cabin, it probably will not matter what you have for fire suppression, it will burn.
Maybe 4-6 big golf course rain birds and a goodly sized pump would do it too. Then you could turn it on and leave (a really good idea).
Don't forget you have to breathe in the midst of a fire and would probably need some protective clothing much like foundry workers wear. I don't know if the surplus market has OBAs but you likely can find the compressed air supply setups the fire departments use.
Frankly, I'd just sign up for insurance and rebuild.
Go talk to a forest ranger, especially one of the fire fighting specialists and see what they say.
It was burning when I put it down!
Good Answers: 27
Re: Water Pressure
08/02/2014 8:02 AM
Now a days the lack or shortage of city water supplies in California should be your initial concern. The amount / volume of water needed for your project, to make it a success may not be available?
vsar
Re: Water Pressure
08/02/2014 2:39 PM
Thank you all for participating in the project. I now have enough information that I can proceed.
Byron
Re: Water Pressure
08/02/2014 3:31 PM
Not so fast!
I think I speak for the group when I ask that you share with us what you intend to do and how you accomplish it. Could be a "how I built my fire protection system" blog.
One word of caution swimming pools are expensive and require either a "pool man" or dedication.
Good Answers: 266
Re: Water Pressure
08/04/2014 1:29 PM
You need to look up the technology of a water canon. Most used for fire fighting reach about 90 ft. The D&E model nozzles a McMaster Carr 3/4 orifice at 100 psi will consume 168 gpm. Gives you about 30 minutes with a 5000 gal tank.
Re: Water Pressure
08/04/2014 4:11 PM
Spray your yard with fire suppressant gel. After the fire, use your hose to rinse off the gel.
Register to Reply 22 comments
Byron Jay (4); Fredski (1); lyn (4); mikenelson6 (1); mrehmus (1); ozzb (1); redfred (1); reward54 (1); Rixter (2); SolarEagle (1); tcmtech (1); Troy36 (3); vsar (1)
