Previous in Forum: Repair To Fire Door   Next in Forum: Columns Just 1' Away From Well and Septic Tank.
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
How Do You Use Infrared Thermography in Civil Engineering?
08/08/2014 10:12 PM
Besides the common infrared thermography application like building energy surveys, cement curing analysis, what other lesser known applications are there for infrared thermography in the civil engineering field?
AB PLC Training onsite, On-Line, training software and more. BIN95.com
Re: How Do You Use Infrared Thermography in Civil Engineering?
08/09/2014 6:11 PM
https://www.icjonline.com/views/POV_2008_05_41_D.S.%20Prakash%20Rao.pdf
08/09/2014 8:54 PM
Thanks Rixter: Great resource. While I knew all the concrete applications, was only aware of tension test, but the article gave good details on tension test with thermograhy. So it helped me out. (plumbing and moisture wasn't unique to civil engineering) We'll see if anyone here knows of other thermography application mostly applicable/unique to civil engineering.
Register to Reply 2 comments
