Previous in Forum: Separation Between Electrical and Instrumentation Ducts   Next in Forum: 10 MW Steam Turbine Generator - Conversion from 60 to 50 Hz
11 comments
Hooking Up a Split Phase Squirrel Cage Motor
08/20/2014 5:06 PM
I had come across this squirrel cage a bit ago and was looking to hook it up to g3et some air movement through our garage. I am simply unsure as to how to wire it all up.
Here are some pics. The very bottom nut and bolt has a wire coming out the side but the top bold was missing the wire. I am guessing that those two are for the hot and neutral but I am unsure as to where the ground would go. Perhaps the nut in the middle?
http://i832.photobucket.com/albums/zz248/half0/IMAG0106.jpg
http://i832.photobucket.com/albums/zz248/half0/IMAG0104.jpg
Those who are afraid of the dark has never seen what the light can do.
Good Answers: 804
Re: Hooking Up a Split Phase Squirrel Cage Motor.
08/20/2014 5:46 PM
Connect the ground to that green screw on the outside.
08/20/2014 5:49 PM
Rather than guessing, just take it to a shop and have them put a male plug on it and be done with it.
Good Answers: 50
08/20/2014 6:23 PM
If you have the 3 wire cord with 120 volt plug attached, the black wire should go to terminal 1 (UNGRD), the white neutral should go to terminal 4, and the green safety ground to the green screw just below the terminals.
Note if you build up your own cord, there is a correct and wrong end to put the power plug onto. You can tell if it's wrong if the black wire is connected on the left side, which is the neutral connection (it will have a silver screw vs a brass plate finish).
ignator -
08/20/2014 6:39 PM
I just use the (W)hite wire goes to the (W)ide side of the plug, method, but I'm not sure if the OP should be messing with this project. I think he should at least have someone have a look at his work before he plugs it in.
08/20/2014 7:21 PM
Oh, come on. Split phase=50/50 chance of getting it right, right?
I bought a new pool pump. 220V single phase. I had my friend who is an electrician come and hook it up.
I'm fine with 110V light switches and receptacles, anything else, I call someone.
08/20/2014 7:59 PM
That 110 kills more than any of them.
I'm good with most of it, (after studying it on the internet), but my main advantage is that electricity still scares me.
Good Answers: 50
08/20/2014 9:20 PM
If this was 480 (which does scare the hell out of me), I would agree, but the worst that could happen is molten metal flying out and burning his eyes. Maybe a little electrocution.
I'm pretty sure the OP will not touch any metal parts of the motor housing or the fan it's bolted to, until the fan runs as expected, and the safety ground is connected properly (as Jraef indicated in his post). And if sparks occur, he learns something.
I hope the OP has some crimp on terminals for round stud connecting (ring type), use this on terminal 1 and 4.
The motor will run hot as there is no back pressure or suction static (caused by a furnace heat exchanger and air plenum's) to limit air flow through the fan. At least that's been my experience using these as cooling fans.
ignator -
08/21/2014 12:23 PM
I used to swap the brass and silver screws on receptacles, then put them back in the boxes and part bins.
I would watch the apprentices wire them up incorrectly over and over, then teach them the proper way to identify where to connect the wires.
Your picture states "...switch red & blk leads"
Just relying on the color of the screw isn't going to work necessarily...not for a noobie. The old adage "black to brass" doesn't make sense when your apprentices and even journeymen hold up a motor with blue or red wires. If the motor you indicate needs reverse (relative) rotation, then black to brass doesn't work.
If they don't know it, teach it...if they can't be taught, hire someone who can.
common knowledge...less common than common sense
Good Answers: 50
08/22/2014 2:02 PM
I inserted the OPs picture that he linked.
I trust the OP from seeing his other posts, that this is not a task that will result in a safety issue. The biggest safety issue is not the 120V electric, but the lack of a belt cover on the V-belt. I never worried about this myself, as I was using it for cooling me, and had no children running about.
If you were an instructor to electrician apprentices, that may be a good thing to eFF with them, but the OP will use materials that are manufactured correctly. I expect he can trust the green, silver and brass screw indications.
For the OP Just doing this simple task of making up and connecting a cord to the motor will improve the understanding of basic termination.
ignator -
08/21/2014 11:13 PM
Split windings really only mean start and run windings controlled by a centrifugal switch mechanism on the rotor. If you look closely inside you will see which terminal goes to the switch and only need to make sure the active or "hot" as you guys call it is connected to the switch. Neutral will be the other terminal with the earth connected to the motor body. Pretty simple really and if you get it wrong it's generally not a major issue but you'll know something isn't quite right so can reverse the connections without letting the smoke out generally. If in doubt connect it up and try it worst you can do is pop a circuit breaker.
Good Answers: 18
08/22/2014 6:08 PM
Jack,
I have two Fans made this way, one I built 15 years ago and put hardware cloth (wire screen) with 1/2"x1/2" holes over all openings. Made legs to hold the fan high enough to blow through the grill on race cars. This one works great.
The second one my son brought home and he tried to wire it just like the one I made, it ran very slow. He ask that I come and wire it up. I ask if he had looked at the wiring diagram on the motor and he had not. That was his problem, this one looked just like the first but it was made for 220 volts.
Look on the capacitor connected to the motor and it will have the wiring diagram if there isn't one on the motor.
Don't forget the protection on all openings.
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Register to Reply 11 comments
gckent (1); ignator (3); Jerrell Conway (1); JRaef (1); kramarat (3); lyn (1); The.Tinkerer (1)
