Previous in Forum: 10 MW Steam Turbine Generator - Conversion from 60 to 50 Hz   Next in Forum: PFC-8 Manual
10 comments
Power Board Connections
08/22/2014 1:32 AM
Hello ,
I am after some help for connecting about six (6) double power points from a separate line distance from Meters (Power Board) 14 metres , allowing a drop of approx. 2.5v ... I would like to install a self tripping Fuse @ the end of the line (B4 the six power points) to save going back to Main Pwr Board if fuse is tripped ...!!!
Is this feasible , or should I say is this a valid exercise or a "waste" of time and money ???
Thank you in anticipation of a prompt solution/advice.
240 volts 50 Hz cable handling capacity 15 amps
Yves
Re: Yves
08/22/2014 1:51 AM
Please elaborate "selftripping fuse"
Sounds like you no need install any power lines if the fuse is self tripping.
On the other handside if you wish to install a fuse that automatically goes back to closed as in not having to be reset by hand you are wasting your time.
Where as if you are talking about a fuse that sits closer to the powerpoints as in being a additional fuse I believe this can be done. Power boards have fuses and are readily availble without even having to install anything else.
Re: Yves
08/22/2014 1:52 AM
Could you, perhaps restate the question?
"six (6) double power points"?
"from a separate line distance from Meters"?
It just goes downhill from there......................................................................
Re: Yves
08/22/2014 3:39 AM
The circuit protective device is there to protect the wiring. If the circuit protective device is in the wrong place, as suggested in the original post, then the wiring to be installed will need to be increased in size to suit the next protective device upstream.
In the UK, one follows British Standard 7671, otherwise one risks a measure of unpopularity with the building's fire insurance company when a fire occurs.
So, consult a qualified Electrician. If the works fall under Part P of the UK's Building Regulations, then a Part P qualified Electrician will be needed.
Don't forget to obtain a test certificate from that person at the end of the job.
Good Answers: 181
Re: Yves
08/22/2014 5:12 PM
"So, consult a qualified Electrician. If the works fall under Part P of the UK's Building Regulations, then a Part P qualified Electrician will be needed."
Part P of the building regulations is not a qualification, it's a requirement to notify building control of certain works which must comply with IET BS7671 amendment 1 2011.
Very little work now falls in the bounds of part P since the amendments of late 2013.
Building control can be notified of work by any trades person. (For a fee)
Re: Yves
08/23/2014 9:49 AM
OK ..Thanks for all the response(s) ...As it has been said B4 a picture is worth .....Unfortunately ..or should I say fortunately ...well "Beauty is in the eye of the be-holder" .... I live in Ozland (Down-Under) ...
The cable is less than 25 metres long from Meter Box , but to "reset" (assuming it has been tripped (= in OFF position for US readers) is a fair walk around the big shed and outside ...!!! Well we are all a "bit lazy" .... All in all , It was a "simple" question , without any "aggro" comment necessary ....
If it NOT constructive and Pro-Active ...Please "abstain" ...
Rgds
Thank you
Yves
Re: Yves
08/23/2014 9:58 AM
"If it NOT constructive and Pro-Active ...Please "abstain"
Admin. have published the CR4 Rules of Conduct.
Only they can alter them.
I know that you are not an Admin. because you don't have one of those little stars by your name.
Thanks for the pic.
Welcome.
Re: Yves
08/24/2014 3:42 PM
I am guessing Ozland (Down Under) is Australia.
So am I this morning, have you read your copy of AS/NZS 3000 as I believe your will find your answer there (that or in your local state electrical regs).
My condolences on your loss to us in the Rugby last night (not).
Re: Yves
08/25/2014 10:51 PM
Hahahahaha ....
A matter of LUCK ....
Anyway thanks for the Ref. to the AS/NZS 3000 ... it is definitely "good reading" ..
I still , do NOT know what make me post that request for help ...
And BTW ..., you are even MORE Down Under that us ..Hehehehehe
Rgds
Yves
Good Answers: 181
Re: Yves
08/24/2014 3:52 PM
I've just spent all afternoon in the pub, so I'm not abstaining.
Re: Yves
08/25/2014 10:53 PM
Good on YOU ,
Neither should you ....abstain !!!!
Rgds
Yves
Register to Reply 10 comments
IdeaSmith (1); jack of all trades (1); lyn (2); PWSlack (1); TonyS (2); yvesmpicard (3)
