Previous in Forum: Tesing of Zinc Oxide Lightening Arrester   Next in Forum: How Do I Verify The Output Power Of Inverter Drive.
33 kv Sub Station
08/28/2014 7:09 AM
can any one tell me what testing and measurement should be carried out while testing and commissioning a 33kv SUB STATION having 2 no 33 kv 315 kva transformer
susanto ghosh
Re: 33 kv sub station
08/28/2014 7:50 AM
The manufacturers of the transformers can do this and it should all be in a commissioning protocol agreed between the Client and the transformer manufacturers. The document just needs looking for; that's all.
Good Answers: 181
08/28/2014 8:55 AM
Why do you need to know?
08/28/2014 9:55 AM
Carnac, the Magnificent can.
Good Answers: 170
Re: 33 kv Sub Station
08/28/2014 9:57 AM
What are the various switchyard equipments that you have in the substation?
Good Answers: 131
08/28/2014 1:10 PM
Follow the ANSI/NETA (InterNational Electrical Testing Association) Acceptance Testing Specification:
Standard for Acceptance Testing Specifications for Electrical Power Equipment and Systems, 2013 edition
http://www.netaworld.org/standards
Good Answers: 42
08/28/2014 2:09 PM
A substation has so many components like incoming 33 kv panel comprising of cable termination , Circuit breaker, CTs , PTs , Protective relays , Meters and other Electrical control systems. Transformers Dry type or Oil Immersed, and LT panel comprising of all switching controls and protective systems . Each and every item has to be tested as per schedule before commissioning. So it is mandatory for the Commissioning engineer to carry out all the tests necessary for each and every item as per standard testing procedure of the Electricity Supply authority of the country you install the substation . There are specified standards and regulations to be followed. So learn it throughly before taking up the job.
08/28/2014 3:54 PM
Sorry we don't answer homework questions here on CR4.
I am assuming this is a homework question and you do not in fact work in or with 33kV substation equipment given the questions you are asking.
Register to Reply 7 comments
electricalexpert65 (1); jack of all trades (1); lyn (1); PeterT (1); PWSlack (1); TonyS (1); V.I.Abraham (1)
