Previous in Forum: How Do I Verify The Output Power Of Inverter Drive.   Next in Forum: Ground Grid Resistance Measurement On A Live Substation
16 comments
Transmission Line
08/29/2014 5:15 AM
how many distance in between two Bird deflection on transmission line.
Re: Transmission Line
08/29/2014 5:41 AM
One wing length. Otherwise the second one would get clobbered when the first one takes off.
Good moaning!
08/29/2014 7:44 AM
One.
08/29/2014 7:51 AM
How cold are the birds?
Good Answers: 145
08/29/2014 8:00 AM
Are the bird deflectors being installed because regulations require them?
If so then the first step is to identify the regulations/laws/permit requirements, etc that you must comply with. Then, either read them or get someone that speaks lawyer to read them.
You probably can find out what organization does the inspections and issues the fines for non-compliance. There is a good chance that they will help you understand the requirements early in the process. In many cases these are the people you paid money to to get your permit.
The people that sell bird deflectors should be very helpful. They can't put food on their table unless they are part of the process of helping you comply with the laws that help prevent birds from bumping into things.
Darwin ... ... no, let's not go there.
08/29/2014 8:43 AM
depends on wingspan
08/29/2014 9:11 AM
I read this first an thought it said 'Bird reflection'. Having dealt with reflections on transmission lines, I was curious as to what bird reflections might be!?
08/29/2014 9:20 AM
I first thought the question was about the change (deflection) in the Catenary curve by having two birds on the wire.
08/29/2014 8:18 PM
The reflection coefficient would depend on the impedance of the type of bird.
08/29/2014 9:30 AM
If the transmission line is good and the load (antenna) is tuned to the frequency, the length of the cable is irrelevant. If there are faults in either, it is possible to get an erroneous reading. Therefore, use several jumper cables, of differing lengths.
Good Answers: 97
08/29/2014 11:56 AM
Using a specialized time-domain reflectometer and a recording arc flash detector, you can log the number of contacts and the location along the line and use this to determine distance between deflectors.
This can also be done for hot air balloon and hang glider deflectors.
CRTL-Z
Good Answers: 918
08/29/2014 12:48 PM
African or European swallow?
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
08/29/2014 11:23 PM
I was going to ask hummingbirds or condors, but I don't think I will.
Speak softly and carry a big stick.
09/02/2014 12:02 PM
Blue !!
No !! Yellow !!
09/02/2014 12:34 PM
I thought it was a sparrow?
09/03/2014 11:03 AM
A sparrow carrying a coconut? No, no. Only an African swallow could do that.
Good Answers: 97
09/03/2014 11:55 AM
"Here we see the elusive Mileormore, as it flitters down from the transmission line and settles on the dune, planting it's head in the sand.
Suddenly, an ear-shattering sound erupts from it's behind, so loud it can be heard for a mile or more."
CRTL-Z
Register to Reply 16 comments
Anonymous Hero (1); Anonymous Poster (1); Brave Sir Robin (2); BruceFlorida (1); Crabtree (1); Fredski (1); JWthetech (1); redfred (3); Rixter (1); standarded (1); Tornado (1); Unredundant (2)
