Previous in Forum: Design of a Control Circuit   Next in Forum: SF6, ACB Working Principles and Comparison Between SF6 and Vacuum Circuit Breaker
9 comments
Delta Wye Connection in Transformer
08/29/2014 4:01 PM
What happen in delta wye ungrounded transformer (primary is delta) if any one delta phase is broken. I am interested to know the behaviour of voltage on secondary wye connection.
Re: Regarding delta wye connection in transformer
08/29/2014 6:02 PM
If one of the delta primary phases (say phase A) is 0 volts, the voltage between the other phases and that dead phase are reduced by a factor 1/sqrt(3). So 2 of the secondary Y phases will have voltage reduced by this factor, and the difference in phase angle will no longer be 120 degrees. In the diagram, black is normal and red is situation with primary delta phase A grounded.
08/31/2014 6:25 AM
Can U please explain me from where u get the factor 1/sqroot3 as a reducing factor.Also I am mot clear if phase A is broken and its voltage become 0 in such case how we get the close delta phasee diagrame.Why not open delta ? Waiting for reply.
08/31/2014 12:35 PM
1/sqrt(3) is the ratio: (red)AC/(black)AC. If you draw a vertical line through Black A, red A, to the base you have two triangles with the same base. The ratios of the hypotenuses is cos(60)/cos(30) = 1/sqrt(3).
If phase A were open there would only be current between B and C, so on the output only one phase would be present, phase BC. Phases AB and CA would be zero.
08/31/2014 11:29 PM
Corrrection: The BC voltage would also go through the CA and AB windings. So the outputs CA and AB would be 1/2 magnitude and opposite in phase with the BC.
08/31/2014 8:47 PM
1/sqrt(3) is the ratio: (red)CA/(black)CA, or (red)AB/(black)AB. If you draw a vertical line (blue) as shown, you have two triangles with the same base with angles at C of 30 and 60 degrees. The ratios of the hypotenuses is cos(60)/cos(30) = 1/sqrt(3). (cosine = adjacent/hypotenuse)
09/02/2014 3:15 AM
I like yr explaination it will be very helpful to me.
Thanks & Regards
Good Answers: 27
08/30/2014 9:41 AM
Transformers main functionality is based solely on the winding "Turn Ratio" and "number of electromagnetic flux induced then cut or interrupted by its windings, while its rated capacity will mainly depend on the (AWG) size of magnet wire used and corresponding core size.
Therefore when one of the primary connections is broken, the net effect will be directly and proportionately reflected to the corresponding secondary winding(s).
vsar
Good Answers: 42
Re: Delta Wye Connection in Transformer
09/04/2014 2:28 PM
Only 2 secondary phases, a and c, remain. The single-phase apparatus supplied from aN and cN will be supplied as usual. The bN supplied installation will be blackout.
Three-phase motor will not start but if it already started the current in phases a and c will be 73% more and the power produced by motor will be only 70% than when was three phases supplied [due to copper losses].See[also]:
IEEE Std 242-2001 ch. 10.3.3.2 Single phasing.
Julius
11/20/2024 6:55 AM
Is that before or after the appropriate circuit protective device has disconnected it?
Register to Reply 9 comments
7anoter4 (1); PWSlack (1); Rixter (4); sensourabh (2); vsar (1)
