Previous in Forum: SF6, ACB Working Principles and Comparison Between SF6 and Vacuum Circuit Breaker   Next in Forum: Difference Between a 3-POLES+N and 4POLES (CB 40A 400V) (Curve D) in 3PH+N Inst
Information Related to Inductive Type Proximity
08/29/2014 10:51 PM
Hi sir, I just want to know the information regarding proximities which are of inductive type. I work in electrical maintainence, frequently the proximity sensor are getting damaged. So are there any type of proximity sensor which are of non breakable type if so please let me know it.
Re: information related with inductive type proximity
08/29/2014 11:06 PM
Good Answers: 225
Re: Information Related to Inductive Type Proximity
08/31/2014 7:57 AM
There's no such thing as non breakable. Every piece of equipment can be damaged given the right (or wrong) circumstances and sufficient determination to do so.
First item on the agenda is to determine how they are being damaged, and then take appropriate steps to eliminate or at least reduce the possibility of this occurring.
If they are being collision damaged, then maybe a flush type shielded sensor coil with remote electronics is the answer, if it is water damage, then consider a submersible type, if the culprit is voltage spikes (very common if located near welding equipment of large motors), then alter the offending circuitry to reduce these fluctuations, or include better filtering in the sense circuitry. Extreme heat can kill them and very cold conditions make them very sensitive to vibration, remote electronics can again ameliorate this problem. Chemical attack is another concern
Once you have fixed the problem, rest assured that some other way will be found to damage them.
Register to Reply 2 comments
