Previous in Forum: Heat Signature Question   Next in Forum: Gas-less MIG
12 comments
Ventilation For Powdered Salt Bags Storage Cum Sieving Room
09/03/2014 1:04 AM
Appreciate recommendation for ventilation arrangement for a powdered salt bags storage cum sieving room of size around 15ftx20ft room.
Re: Ventilation for Powdered salt bags storage cum sieving room
09/03/2014 1:12 AM
No problem.
A 15ftx20ft room has no volume without a 3rd dimension.
No problem.
If you want to present some actual facts, maybe someone can help.
I won't play 20 questions, but think about it.
<unsub>
09/03/2014 1:17 AM
Thanks.The hieght is 15ft.
Anonymous Poster #2
09/03/2014 1:41 AM
That was constructive.
09/03/2014 2:39 AM
If the dust does not leave enough breathable air in the room you might want to block access to the room. Closing the door seems appropriate anyway plus is cleaning from time to time. What sort of salt is it?
The salt dust will settle on your machine and everything in the room. Ventilation just brings the dust outside the room which in conjunction with moisture might get nasty.
Make sure no moisture gets in the room and materials in the room are up for the task. Avoid flat surface so the dust is not piling up on edges that are hard to clean.
In Summary: recommend no ventilation
09/03/2014 2:46 AM
So why store the bags in a room? How about a cage with a roof over it instead, Murphy?
Good moaning!
09/03/2014 3:45 AM
I think we are due to get a explanation on:
Sieving = dust
Storage not much dust
09/03/2014 4:38 AM
I agree. One sentence is not much to go on, is it?
Good moaning!
Re: Ventilation For Powdered Salt Bags Storage Cum Sieving Room
09/03/2014 8:21 AM
I don't like ANONS, you're a prime example of why
09/03/2014 7:45 PM
Use a big fan, pulling from the roof with vents at the bottom.
<unsub again>
09/03/2014 8:03 PM
As others have (vaguely) indicated could you please provide a lot more information.
For example, are you talking about a small 2 person operation in a small rural town in Pakistan or thousands of bags an hour using automated machinery in a factory in Ohio!
More information please, oh and what type of salt as there are many and some are corrosive, toxic, explosive, etc (we cannot just assume common table salt).
09/04/2014 10:47 AM
Expected a suggestion or guidance based on experience as it is supposed to be a place for the Engineer's for news and discussions.
09/08/2014 3:22 PM
We need more information as I have mentioned in post #10.
With so little to go on any assumptions we make and guidance we offer could be next to useless and potentially even dangerous if the salt is flammable or toxic (for example).
Please provide more information!
Anonymous Poster (1); Crabtree (2); Fredski (1); IdeaSmith (2); jack of all trades (2); lyn (2); pokalasrao (2)
