Previous in Forum: Pipe Schedule number   Next in Forum: Steam and IC Engines
Compressor Efficiency Calculation?
07/03/2007 1:59 PM
How to decide that which type of compressor use for compressed air efficiency and how to calculate its capacit and efficiency?
Re: Compressor Efficiency Calculation?
07/03/2007 11:40 PM
First what is the compressor used for, Control air, Start air, Power tools, if of those you can use a low capacity piston compressor as air will be pressed up in air bottle. for usng air at high capacity ie, shotblasting then a vane/screw type compressor will be required. The manufactures are usualy very helpful for calculating capacity as for efficiency we all strife for 100 % but seldom achieve it.
07/04/2007 8:33 AM
It's generally assumed that, in compressors over 10 HP, that each HP of power will generate about 4 CFM of compressed air at 90 PSI. Much more information can be obtained about compressors and compressed air at www.about-air-compressors.com
Register to Reply 2 comments
