Previous in Forum: Neutral Shifting   Next in Forum: 05 Vibe Base Motor Mounts?
11 comments
Earthing In Motor Terminal & Body
09/03/2014 7:21 AM
We have earthed the terminal box of the motor with the cable from the respective feeder of the MCC room.. again I was asked to do earthing on both sides of the motor body.. my question is since we earthed motor terminal box already, why motor body earthing required..? Since motor terminal box and motor body are mechanically connected.
Re: Earthing In Motor Terminal & Body
09/03/2014 8:01 AM
It is conceivable that the terminal box might work loose from vibration. But then, either earthing connection could also work loose. Maybe there should be 6 earthing connections, in case 5 of them work loose. Isn't contingency analysis fun?
09/03/2014 8:19 AM
redundancy just might save your life
09/03/2014 8:58 AM
Go back to the person who asked you, and ask "why?".
Good moaning!
09/03/2014 9:09 AM
Or just do it and move on to something more productive.
09/03/2014 9:43 AM
Good point.
Good moaning!
Good Answers: 122
09/03/2014 9:44 AM
The feeder cable ground is there to protect equipment & personnel from exposure to an electrical ground fault in the cable between the switchgear and motor and also to provide an alternate path for the equipment ground.
The equipment ground (motor body) is there to protect equipment & personnel from exposure to an electrical fault in/at the motor and/or the equipment the motor is attached to.
If the cable ground is damaged or severed, and the equipment ground is intact and functional, the motor as well as whatever it is attached to will still have ground fault protection and personnel will also be protected.
09/03/2014 9:44 AM
Since you don't know why, how can you speculate about why not.
Just do it!
09/03/2014 11:16 AM
The answer was in your question. The motor terminal box and motor body are mechanically connected.
The bonding is the electrical connection.
common knowledge...less common than common sense
09/03/2014 11:35 PM
Is the terminal box insulated with a rubber gasket? Best to have as many earthings as you can to keep everyone safe.
"Real Bass Players" do not use picks
09/04/2014 1:38 AM
Dear Mohsin,
Your question is relevant. The terminal box you earthed is fixed to body through bolts and has a gasket in between. The gasket is basically provided to make it environmentally protective and proper packing ... but this is electrical insulator. As far as bolts are concerned they may be 4-6 in number but are made of high resistance material normally. Therefore the earthing is demanded on motor body. I don't understand requirement of earthing on both sides of the body... One side .. I can understand. If there are items connected with screws and bolts on either side don't earth them, earth main motor body at the provision made and you may provide a copper strip/wire jumper to bolted parts. This meets Indian standard. You may check for standards if you are elsewhere. I am sure you will certainly agree that a human life saved is much -more costly and valuable than a motor and its earthings.
Let us discuss the practical issues not the classroom.
09/04/2014 3:39 AM
Blimey, could have done it by now.
Already this morning, I've mended the downstairs cistern... (leaking flap valve... it's my age)
Register to Reply 11 comments
Crabtree (2); Fredski (1); Jimh77 (1); lyn (1); M.R.Iyengar (1); SHOCKHISCAN (1); The.Tinkerer (1); Tornado (1); user-deleted-1105 (2)
