Previous in Forum: Kirchhoff Current Loop in Resistor Diode Ladder Network   Next in Forum: Transmission System Part in SolidWorks
Nitrogen Calculation
09/03/2014 9:53 AM
Hi
I would like to know the nitrogen volume calculation
To pressurize 10 cubic meter of pipe line ,how much volume nitrogen required on the below condition ?
1. only to purge at positive pressure?
2. pressurize with 30psi ?
how much gallon of liquid nitrogen required fill 1 cubic meter at atm pressure?
how much gallon of liquid nitrogen required fill 1 cubic meter at 30psi pressure?
please share your stuff ..
This discussion was "closed" on 09/03/2014 11:30 AM. No new comments are allowed.
Message from admins:
Duplicate Thread http://cr4.globalspec.com/thread/97423
Re: NITROGEN CALCULATION
09/03/2014 10:47 AM
You've already asked this in another section, Mildred. There's no need to double-post.
Good moaning!
09/03/2014 11:08 AM
as usual,the OP FAILED to state why they need to know, so I'm left to assume this might possible a welding or leak question???if its welding or corrosion related this might helphttp://www.tubenet.org.uk/technical/whypurge.html
Register to Reply 2 comments
