Previous in Forum: Electricity Generation Method Using Workout Equipment.   Next in Forum: Nitrogen Calculation
11 comments
Kirchhoff Current Loop in Resistor Diode Ladder Network
08/25/2014 9:55 AM
I am looking for an approach on how to apply Kirchhoff current / voltage law in the infinitely long diode ladder network. Can anyone help me with this ?
I am looking for 1D differential equation or an implicit equation involving diode current in individual loops.
Re: Kirchhoff current loop in Resistor Diode Ladder network
08/25/2014 10:51 AM
This looks like a homework question to me. From the CR4 FAQ #14:
  • Do your own homework. CR4 is not a homework cheat site. While some here might relish the opportunity to sharpen up old rusty skills by working the homework problem, consider the following and consider it well. If you cheat on your homework by using someone else's answers, you are only cheating yourself, because the purpose of any homework or other academic assignments is to help you learn - by practice, repetition, and self-discovery.
Here are two big hints. You should already be familiar with the Schokley diode equation for your class. Google is your friend.
Good Answers: 67
08/25/2014 12:03 PM
How would you solve this were the diodes resistors instead?
08/25/2014 12:23 PM
Good point. I believe it is actually easier to solve this problem with identical diodes than all resistors but the fundamentals are still the same.
Good Answers: 67
08/25/2014 12:45 PM
Btw, I wanted to mention that I found one of your replies quite helpful. I don't recall the thread exactly (else I'd provide a link for context, but it was a thread by Shyam where he wanted to measure picoamp-scale current), but in your reply you mentioned using a shielded, twisted-wire pair rather than coaxial cable.
I had a problem with RFI in an ELF receiver I built recently. I was using coax but was picking up all kinds of interference from a local AM radio station. I followed your advice on that thread and changed the cable over to shielded, twisted-pair and the problem (largely) went away. I was actually able to see some very faint signals after that, one of them I'm sure was the 19.8 kHz signal from the U.S. Navy's HEH submarine transmitter on Australia's west coast. Not bad given the distance.
My current antenna spans the frequency range 40 Hz - 22 kHz. Building a new loop having a corner frequency less than the first Schumann Resonance at around 7.83 Hz.
Thanks.
08/25/2014 2:05 PM
Cool.
You're very welcome!
08/28/2014 9:11 AM
I think you replied to wrong comment. Unless europium mkii has found a way for ELF signal sources to drive an LED. Now that would be colossally green.
Re: Kirchhoff Current Loop in Resistor Diode Ladder Network
08/25/2014 6:49 PM
Everything to the right of the first resistor and diode is just a repeat of what you are trying to compute. This reduces the problem to a simple quadratic equation.
08/25/2014 11:54 PM
The solution depends on the accuracy needed as usual. If ideal diodes are considered the following will apply:
Looking at the circuit from the left, when the top terminal is positive to the bottom terminal the current may be calculated as (Vsupply - Vdiode)/R(first). (Vdiode is usually 0.6V for Si diodes). All other diodes will not conduct as they can only get a portion of the break down voltage of the first diode, which will not be adequate to break down any other diode. In other words only the first loop is conductive - all other loops are open circuit.
When the polarity is reversed all (ideal) diodes are open circuit, so the current will be zero. In other words all loops are open circuit.
If practical diodes are considered, one must reconcile Vf versus If characteristics of each diode, the band of variations, etc, which may result in the problem being too complex to solve mathematically, demanding simulations and what-if scenarios.
Hope this helps.
08/26/2014 7:22 AM
assuming an exponential (approx. Ebers-Moll) diode model, the voltages on the diodes will be close to k * log(log(log(log....Vf))), Vf>:0.
Good Answers: 122
08/26/2014 5:02 PM
If the resistors and diodes are identical then: Rt = R/N
Otherwise: 1/Rt = 1/R1 + 1/R2 +1/Rx
08/26/2014 9:46 PM
No. You never get a linear network when half of the parts are non-linear parts. Your equations imply a linear network.
Register to Reply 11 comments
cjanand (1); europium mkII (2); redfred (5); SHOCKHISCAN (1); Snel (1); Tornado (1)
