Previous in Forum: Welder Qualification Required Seperaely or Not   Next in Forum: EOT Crane Design
12 comments
Vacuum Pump
09/06/2014 8:56 AM
which is the best vacuum pump rotary vane pump or rotary piston pump?
Pathfinder Tags: 9HRZSGEN
Good Answers: 11
Re: Vacuum Pump
09/06/2014 9:01 AM
no doubt the piston type
Re: Vacuum Pump
09/06/2014 11:02 AM
The one with a ceramic shaft.
Good Answers: 11
Re: Vacuum Pump
09/06/2014 8:34 PM
oh my, lyn. its pretty hot yet handle it with good care, oh it's brittle.
Good Answers: 48
Re: Vacuum Pump
09/06/2014 6:13 PM
Both, although it depends.
Re: Vacuum Pump
09/06/2014 7:37 PM
I prefer an ion pump with a good bake out to at least 120°C.
Re: Vacuum Pump
09/06/2014 8:15 PM
I thought pistons were usually reciprocating. They don't do much when rotating axially.
Re: Vacuum Pump
09/07/2014 2:05 AM
The rotary vane is the better of the two.
Re: Vacuum Pump
09/07/2014 6:31 AM
The more expensive one.
Re: Vacuum Pump
09/07/2014 9:18 AM
Plus the one that works!
Re: Vacuum Pump
09/07/2014 6:35 AM
When you use the term 'vacuum' it really means that you are reducing pressure by moving air/gas from one area to another ( usually the atmosphere ).
Why the preamble? It is because the answer to your question depends on YOUR answer to this question;- Which do you want, rapid removal of air or very low pressure?
A domestic vacuum cleaner does the former a piston pump the latter.
Jim
Re: Vacuum Pump
09/08/2014 1:27 PM
The standard vacuum pump for conveying materials is a roots blower.
Re: Vacuum Pump
09/08/2014 4:29 PM
If you want a reasonable answer you should tell us how this vacuum pump is going to be used and what amount of vacuum you are going to be using. Either of your choices could be correct depending upon usage.
Register to Reply 12 comments
Holzfeller (1); IdeaSmith (1); JIMRAT (1); lyn (1); No_eing (1); Noudge79 (2); Poison (1); redfred (1); silvCrow (1); Tom_Consulting (1); Tornado (1)
