Previous in Forum: Random Change of Time and Date on Point of Sales   Next in Forum: Modern Communication
13 comments
India - Member - Justin Anto Engineering Fields - Electrical Engineering - Marks never made me laugh, but good memories did
Fibre Optic Patch Cord Specification
09/14/2014 7:53 AM
I need to find the power loss of a light signal when it is travelling through a patch cord.
Patch cord specification is given below.
ILA1: 0.15dB RLA1: 52.5dB
ILA2: 0.13dB RLA2: 52.8dB
ILB1: 0.08dB RLB1: 51.0dB
ILB2: 0.22dB RLB2: 52.8dB
How can I find the loss of the cable from the above given specification ?
I used laser light for the transmission with a wavelength 1550nm.
If you can't find a way, make one........
Good Answers: 27
Re: Fibre optic patch cord specification
09/14/2014 8:44 AM
By measuring the output of the source, then connect your patch cord and measure the other end using a light meter sensitive to the laser frequency. Compare the measured parameters.. Make sure no color, or light filtering is in place that will interfere or attenuate your signal.
Whatever resulting losses encountered will determine the quality of the fibers used inside the patch cord!
vsar
09/14/2014 8:52 AM
The loss per meter/foot or some length should be:
1. In the cable spec
2. Available on-line at supplier data.sheets
3. By measurement.
The loss through the cord isn't the problem. It's the loss at the connections that's the biggest worry. That can not be estimated. It must be measured.
Good Answers: 44
Re: Fibre Optic Patch Cord Specification
09/14/2014 11:46 AM
What Lyn said
Good Answers: 12
09/14/2014 11:46 PM
ILA = Insertion Loss Attenuation
RLA = Return (or Reflected) Loss Attenuation
I will hazard a guess that the fiber you have is duplex hence the numbers 1 and 2.
Insertion Loss is expressed in dB and is defined as 10*log (Po/Pi) where Po= Power Out and Pi=Power In.
I also will guess hope you can fill in the blanks so I don't completely do your work for you.
09/15/2014 4:24 AM
hellow daffy, your answer is really helpful for me. Can you shed some light about ILB & RLB.
Good Answers: 12
09/15/2014 6:30 PM
I thought I did by telling you what the acronym is. Sorry but its too long to explain theory in a thread...I do work. Google may be your friend.
Good Answers: 145
09/15/2014 9:51 AM
No disrespect intended but I got a smile when I saw that someone was using the Internet to get technical information from a character named Daffy Duck. The answer was good but overall it was funnier than most of the "caption this" postings we have had this year.
Da Da Da Dat's All Folks
Good Answers: 12
09/15/2014 6:22 PM
No one, I say, no one makes fun of thith black duck.
09/15/2014 5:01 AM
power loss in dB =ILA1+patch cord length *loss dB/KM( from Fiber MFr Data i.e. dB/KM @ 1550nm) +ILA2
this gives you the attenuation loss of Patch Cord for particular length.
09/15/2014 5:05 AM
Good Answers: 27
09/15/2014 12:18 PM
For design purposes, all Theoretical methods of finding losses will be only as good as the result obtained from the calculator. The results will be all estimations which are just good in papers..
For any actual and functional applications, One has to do an actual testing in order to validate any written specifications and/or compared to any pre-computed designed results.. Actual testings which are a must for all non-academic functions, and to come up with a more functional values validated for real world applications.
vsar
09/15/2014 2:12 PM
thanks for the advice... but can you just tell me what is meant by ILB and RLB.. that is what i am seeking for..
Good Answers: 27
09/15/2014 3:45 PM
Study the field of communications, and its associated control circuits. Then focus on the medium you are interested in..
Good luck!
vsar
Register to Reply 13 comments
BruceFlorida (1); cuba_pete (1); daffy (3); hjunaid (2); justinanto1987 (2); lyn (1); vsar (3)
