Previous in Forum: Heat Exchanger   Next in Forum: Which Is Good Centrifugal Or Piston Pump
9 comments
India - Member - New Member Engineering Fields - Mechanical Engineering - New Member Engineering Fields - Piping Design Engineering - New Member
Surface Tension And Vessel Blanketing
09/16/2014 1:34 AM
Hello everyone,
I have a vessel containing mineral oil at 300 degree centigrade, we use niitrogen gas to pressurise and isolate system from external environment (to avoid oxidation).
My question is, Does surface tension of fluid play any role in maintaining the solubility of nitrogen gas into mineral oil ??
Please, do share your views on this.
Thanks,
- NTR
(engineering)...is the art of doing that well with one dollar that any bungler can do with two..
Pathfinder Tags: Surface tension
Re: Surface tension and vessel blanketing
09/16/2014 1:42 AM
Not as much as the pressure of the gas and temperature of the oil.
Probably not any, but I'm not 100% sure.
Good Answers: 109
09/16/2014 2:52 AM
Surface tension and maintaining solubility?
If any it will be more of a hindrance.
Do you want the gas in the oil?
What did your internet search come up with?
09/16/2014 6:19 AM
No, I don't want gas in the oil.
I have seen oil datasheets specifying surface tension of liquid at a temperature, but have never seen anyone referring surface tension for any of the design purpose.
Thanks,
_NTR
09/16/2014 4:02 AM
Not as much as temperature. In general, the higher the temperature, the lower the solubility, though there is a distinct absence of data here.
Might be worth some experimentation, perhaps?
09/16/2014 6:29 AM
My understanding is that, a fluid with higher surface tension will have larger tensile forces at the top layer and thus gas cannot dissolve in the liquid. But considering the different fluid at same temperature and pressure with lower surface tension, the solubility would be more.
Please correct me, if I'm wrong
Thanks,
- NTR
Good Answers: 137
09/16/2014 11:49 AM
Highly unlikely it would make any discernable difference. Gas solubility likely to be different for a different fluid, but not because of change in surface tension.
And as you're dealing with a specific fluid it's irrelevant.
Good Answers: 92
09/16/2014 8:48 AM
ASSUMING (yes, there's that word again!) that the temperature and pressure are static and that the mineral oil is being held in the container as opposed to circulating through it and then to a process area of different parameters- NO.
Temperature and pressure are parameters that affect the solubility of gases in liquids. Surface tension may affect the rate of exchange, but it will not affect the overall solubility. So, providing the system is maintained at a steady state and the materials are in contact long enough to reach equilibrium the levels of dissolved gas will be the same. If you are using this as a buffer tank the answer may be different.
Re: Surface Tension And Vessel Blanketing
09/17/2014 1:04 AM
Thank you all for sharing your ideas and making me clear that surface tension has no effect on solubility.
But, what would be the reason for specifying Surface Tension in Oil data sheets ??
Thanks,
- NTR
Good Answers: 92
09/17/2014 12:13 PM
Several possibilities. It is a physical parameter, and there are situations where someone may want to know it. Usually though, I find things like that are because "we had to do it for X situation so we just put it down for all the products".
Register to Reply 9 comments
Codemaster (1); IdeaSmith (1); JNB (2); lyn (1); ntr (3); PWSlack (1)
