Previous in Forum: Welding Of Tubes Of Titanium Material With Tubesheet Of Carbon Steel   Next in Forum: Hot Bar Bonding Machine
Oil Refinery Delayed Coker Unit Wet Gas Compressor Experience
09/16/2014 1:47 PM
We at knpc , kuwait operate a coker Unit in good operation since 1987. The Wet gas Compressor in this Unit is always operating with Seal Oil & Lube oil Contaminated with Coke Fines & residual Gases. Do other Coker Wet gas Compressors hv similar issues. Our hs the oil seal rings Seal Oil system. We do change them once in 2 years. But oil is always with coke fines & it greatly affects the Drive Steam Turbine Control System. Kindly Share your experience.. Laks Kuwait National Petroleum Company, kuwait
Pathfinder Tags: Refinery Coker Compressor
Good Answers: 97
Re: Oil Refinery Delayed Coker Unit Wet Gas Compressor Experience
09/16/2014 7:57 PM
You need balanced or positive pressure systems. Can I get a line on cheep gas?
CRTL-Z
09/17/2014 11:10 PM
http://refiningcommunity.com/topic/performance-of-wet-gas-compressor-in-delayed-coking-unit
Register to Reply 2 comments
