Previous in Forum: Oil Refinery Delayed Coker Unit Wet Gas Compressor Experience   Next in Forum: AWS D1.1 Prequalified WPS
Hot Bar Bonding Machine
09/17/2014 3:16 PM
Has anyone tried to make a DIY device that works like a hotbar bonding machine?I need only from time to time to change FPC( flexible printed circuits) on LCD ,using ACF( anisotropic conductive film),so spending about several thousand USD on that machine is not good for me.Thanks
Re: Hot bar bonding machine
09/17/2014 3:45 PM
Have you considered using a strip of (say copper) bar or plate that can transfer the heat from a large wattage soldering iron fairly uniformly and quickly?
09/17/2014 4:05 PM
Having no clue exactly what you are trying to do:
Consider a hot plate, or copper bar suggested above, covered with Teflon tape.
3M 5451 PTFE Glass Cloth T...$309.00ULINE
Or look at a manual PE bag making machine.
09/17/2014 4:14 PM
Maybe you could just rent....or piece one together with refurbished parts....
http://www.a-i-t.com/hot-bar-soldering-equipment
Good Answers: 58
Re: Hot Bar Bonding Machine
09/17/2014 10:47 PM
I have built these devices. There are several ways to do this.
1) You can modify a Weller soldering gun.
2) You can use a heater bar from a gas burner ignitor.
3) You can use a nichrome or resistive wire loop
4) You can purchase a used one
09/18/2014 1:04 AM
Thank you for the feedbacks to All of you.
@welderman: Do you have any pictures of the machines you built?
09/18/2014 3:41 PM
So, nothing :-(
Register to Reply 6 comments
jack of all trades (1); Jane11 (2); lyn (1); SolarEagle (1); welderman (1)
