Previous in Forum: Full Form of IE2   Next in Forum: How To Design Auto-Changeover Mechanism/System
10 comments
CDF Of An Induction Motor
09/17/2014 7:00 AM
Hi,
What is the CDF (Cyclic Duration Factor) of an induction motor? If the required capacity is 5 kW - what is the capacity in kW after taking into consideration of say 40% CDF?
Regards,
Anonymous Poster #2
Re: CDF of an Induction Motor
09/17/2014 7:10 AM
09/17/2014 7:25 AM
addition........if there is 150 starts/hour for the induction motor into consideration.
Regs,
Anonymous Poster #2
09/17/2014 7:35 AM
Anonymous Poster #3
09/17/2014 7:48 AM
Anonymous Poster #4
09/17/2014 9:23 AM
Looks like SE's MO.
Anonymous Poster #3
09/17/2014 9:41 AM
Anonymous Poster #5
09/17/2014 7:38 PM
Re: CDF Of An Induction Motor
09/17/2014 9:42 AM
5 kW.
You fail to grasp so much.
Good Answers: 25
09/18/2014 8:04 AM
Motors are designed for particular applications. If motor is running in cycle i.e 4 minutes running time and 6 minutes rest then it is called 40% CDF motor. The duty cycle is 10 minutes. There are many applications where such cyclic duty exists. Some are 40%, some 60%, some 100%. For selecting motor you should know your cyclic duty requirements.
Good Answers: 42
09/26/2014 5:58 AM
IEC 60034-1 ch.3.11 cyclic duration factor:
"the ratio between the period of loading, including starting and electric braking, and the duration of the duty cycle, expressed as a percentage"
There are 10 duty types. In order to calculate the rated power from CDF you have to precise the duty type and all other necessary data [Jm,Js ,ΔtD , ΔtP and so on]
Julius
7anoter4 (1); Anonymous Poster (7); lyn (1); suresh sharma (1)
