Previous in Forum: Could The Postie Get A New Form Of Transport Soon?   Next in Forum: ELIO Motors
8 comments
Chevvy Aveo Break Switch Problem
09/17/2014 12:24 PM
My chevvy aveo wont go oht of park unless i hit an anti lock button and then it works. The break lights are also off. I had my friend fix it befor by pressing a spring by the pedal but the problem is , i dont know where abouts its located to do it myself. Anyone know??
Re: Chevvy aveo break switch problem
09/17/2014 12:52 PM
The brake pedal is the flat one to the left of the accelerator pedal.
It's down by your feat.
09/17/2014 12:55 PM
Ya i know where the break pedal is.. Im talking about the spring to push. The "dual contact switch"
09/17/2014 1:00 PM
Good Answers: 69
09/17/2014 1:02 PM
About 3/4" from the pedal's connecting rod, it is upwards (see in the middle of the drawing below), you need to move the driver's seat as far as it goes to give you room; I heard is a snap in replacement, you should hear a click.
Here is the part alone:
Re: Chevvy Aveo Break Switch Problem
09/17/2014 7:05 PM
its "Brake"
09/17/2014 10:31 PM
But if the lights are off, didn't it break?
Good Answers: 203
09/17/2014 11:02 PM
No. It isn't BREAK or BRAKE! It's BROKEN!
Good Luck, Old Salt
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
09/18/2014 8:37 AM
Pressing a spring is probably not fixing. Suggest you have someone do a little investigation.
Speak softly and carry a big stick.
Register to Reply 8 comments
Brave Sir Robin (1); Fredski (1); lyn (1); old salt (1); SolarEagle (1); standarded (1); T.banner8 (1); Yahlasit (1)
