Hi there!
I'm design a product containing one ordinary rigid PCB and one smaller flex card. The issue here is to connect the cards to each other. I'm thinking of making the flex card as a card and cable in one, eliminating the need of a separate cable.
I want to know if anyone has any experience in soldering flex cable directly to solder pads on a PCB. Is this possible? What process can be used? Known problems? What additional strain relief may be considered? The whole package will be moulded with some plastic material on final assembly, so the mechanical forces on the solderings are limited to the ones associated with assembly.
Thanks, Fredrik
