Previous in Forum: Seating a Keyway   Next in Forum: Tubing & Tube Fitting
Need Some Pictures of Stub In, Stub On, Flange
09/27/2014 1:50 PM
my english very bad. i try to ask.
please give me some really picture (in market) for stub in, stub on, stub end, flange.
Re: I need some picture of stub in, stub on, flange.
09/27/2014 2:11 PM
Good Answers: 61
Re: Need Some Pictures of Stub In, Stub On, Flange
09/27/2014 8:33 PM
Supraba.
Point #1 - The Stub-End is one of the two elements used to make a special type of Flanged connection. The other element is the loose flange (called a Van-Stone Flange). The Stub-end might be made of Stainless Steel and the loose flange could be made of Carbon Steel thus reducing the cost of the connection. The link provided by Lyn should answer all your questions there.
Point #2 - Stub-in and Stub-On (this is the correct spelling, not what is shown in the picture) are methods for making Branch connections that can be used when allowed by the Piping Code and the Pressure and Temperature conditions of the line. See the images below.
Link to Stub in and Stub-on:
https://www.google.com/search?q=images+of+stub+in+%26+stub+on+branch&biw=1024&bih=609&tbm=isch&tbo=u&source=univ&sa=X&ei=4E8nVJLuOriasQSayoDYBw&ved=0CB0QsAQ#tbm=isch&q=images+of+stub+in+%26+stub+on+branch+connection&facrc=_&imgdii=_&imgrc=Yzqjdtrdq6uwOM%253A%3B2F1D743H8kjlPM%3Bhttp%253A%252F%252Fcr4.globalspec.com%252FPostImages%252F201107%252F2_23A8013B-DBD3-F6A0-566F46AE715D79A1.jpg%3Bhttp%253A%252F%252Fcr4.globalspec.com%252Fthread%252F70341%252FStub-In-Stub-On-in-Piping%3B400%3B259
Do it once and do it right
Register to Reply 2 comments
