Previous in Forum: Need Some Pictures of Stub In, Stub On, Flange   Next in Forum: Threads
Tubing & Tube Fitting
09/27/2014 10:07 PM
Dear All
Due to client requirement for the client prepare to use copper tubing and for the fitting stainless steel, are we meeting the full tightness on the fitting side any possibility of leakage???
Any advise please....
Regards
Good Answers: 176
Re: tubing & tube fitting
09/28/2014 6:27 PM
Your question cannot be answered.
There's no way I can know the quality of the tubing, the quality of the fitting, the quality of the the device being connected to and the skill of the installer (proper installation is not trivial, it is a craft). Nor have you revealed the basic process conditions of pressure/vacuum, temperature, medium, line sizes or any of the site variables like vibration.
As my daddy used to tell, "Son, there's nothing that somebody can't make cheaper, but remember, you only get what you pay for." No truer words were ever spoken. Junk fittings and junk tubing might tighten down enough and not leak long enough for the invoice to be paid, but on the first re-make it's Leak City.
The topic of leaks in tubing and fitting is much bigger than I'm willing tackle as a web topic. So I'll provide URL links (down below) to four documents from high quality fitting vendors, which you can peruse at your convenience.
A very comprehensive tome on tubing and fittings is on Scribd, a download site (requires registration and an upload a document in order to download a document):
Instrumentation Tubing and Their Connections, by Nirbhay Gupta
http://www.scribd.com/doc/12725993/Instrumentation-Tubing-and-Their-Connections-Nirbhay-Gupta
Parker Tube Fitting Troubleshooting Guide UK.pdf
http://mdmetric.com/4100/Chapter%20G%20UK.pdf
Hoke GyroLok Fitting Installation Manual 77100_0506_lo.pfd
http://www.circle-seal.com/alternative_fuels/alt-fuel_pdfs/77100_0506_lo.pdf
Canada - Member - New Member
10/01/2014 9:53 AM
The question is very easy to answer, there is always a possiblity of leakage, no matter how well the connection is"designed", if the design isn't properly executed you know the result. But I am sure your links will be appreciated.
Never stop learning
