Previous in Forum: Star Delta Cable   Next in Forum: Help with VDF Pump Control
DG Set
09/29/2014 3:00 PM
is Diesel generator(DG set) required DC supply.why DG set required DC power supply
Pathfinder Tags: DG
Re: DG Set
09/29/2014 3:16 PM
It needs whatever it says in the instructions, Mildred, otherwise you may find either it won't work or it will get damaged, or possibly both.
Good moaning!
Good Answers: 445
Re: DG Set
09/29/2014 9:13 PM
Unless it's an air-start diesel you'll need a source of starting power, unless it's a hydraulically controlled system you'll need a source of control power.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Re: DG Set
10/02/2014 12:29 AM
for cranking the Engine tou have 3 Options -
1. Electrical Starter
2. Air Starter
3 Hyd Starter...
If you have ordered the DG set with Electrical Starter, you will need the battery bank to supply the power to thie Electrical Starter..
Register to Reply 3 comments
Crabtree (1); RAMConsult (1); vishram lele (1)
