Previous in Forum: V42JAB1   Next in Forum: Reqd. ISO 3555 for NPSH Test
Internal Components of Glycol Surge Drum
09/30/2014 5:08 AM
Internal components of Glycol surge drum.
I need information on the internal components of glycol surge drum in order to determine the likely corrosion degradation process in the drum. Emma.
Re: Internal Components of Glycol Surge Drum
09/30/2014 6:14 AM
It may be possible to add corrosion inhibitor chemicals to the glycol, and then designing a carbon steel surge drum with a corrosion allowance on the order of 1-2 mm.
Another way is to use an expansion tank with a rubber bladder inside. Local availability might be an issue.
Becoming a member of NACE (National Association of Corrosion Engineers) could give access to the best data. A lesser level of data can be had from material compatibility tables often published by valve and pump vendors.
09/30/2014 9:23 AM
Oh, come on! It is on the process equipment data sheet for the vessel! Look it up in the facility's records using its tag number!
Good moaning!
09/30/2014 9:53 AM
Bill of materials for drum + Matlab or other materials compatibility tables = likely corrosion degradation process.
Good Answers: 137
09/30/2014 11:22 AM
Presumably it's mostly glycol. How would anybody on this forum know what else might be in there?
09/30/2014 3:39 PM
What about its periodical burst/collapse insurance inspection reports? Surely you can gain access to those?
Good moaning!
Codemaster (1); Crabtree (2); lyn (1); Tornado (1)
