Previous in Forum: High Voltage Cable Laying   Next in Forum: Starter Question
10 comments
Cable Size for Drive
10/04/2014 8:17 AM
I have 55kw,3 phas ,415V,50hz motor with VFD.what could be size of cable for motor to starter.
Pathfinder Tags: drive
Re: cable size for drive
10/04/2014 9:45 AM
The cable could be a lot of different sizes depending on the environment of the motor, driver and cable run. It should also matter how critical it is for this motor to run. The electrical codes for the location of this motor will be a good guide but depending on the missing criteria they may not be sufficient. There will also be the question of conductor size that will fit the VFD and motor connections.
You must properly do your own homework before you will understand the reasoning behind any answer you find.
10/04/2014 10:27 AM
Provide the following data :-
a.Total load,
b.Duty factor
c.Distance between source and load
d.Cable laying details
e.No of cables in trench
10/04/2014 12:16 PM
Measure it! If it isn't there yet then it will be whatever the qualified electrician who installs it for you selects; ask him/her!
Good moaning!
10/04/2014 2:17 PM
Should be around 100 FLA for motor....multiply it by 1.25% which gives you the MCA (minimum circuit ampacity)...
http://www.gridcables.com/pdfs/3-core-al-armd.pdf
Good Answers: 181
10/04/2014 7:55 PM
You don't seem to have any idea on cable sizing (look at his previous posts).
Why should a group of random guys do the job you're paid for?
10/05/2014 12:08 AM
Ask VFD/motor manufacturer what type of cable is suitable for this.Is the motor suitable for inverter duty?.
pnaban
Re: Cable Size for Drive
10/06/2014 8:37 AM
It depends on whether it is copper, aluminium or something else, all of which you seem to be keeping to yourself, together with any indication that you know what the applicable electrical installation code is for your location. That is why the post is being treated contemptibly.
Good moaning!
Good Answers: 42
10/07/2014 11:56 PM
Julius
Good Answers: 42
10/10/2014 10:15 AM
As information only see:
http://www.beldenapac.com/sites/default/files/resource/PBAI_121_VFD_Cable.pdf
and also [may be] :
http://www.gozuk.com/blog/cable-length-between-vfd-and-motor-865061.html
Julius
10/19/2014 9:12 AM
To understand more about cable selection, please check out this http://www.psa-outline.com/cable-selection/
Register to Reply 10 comments
7anoter4 (2); Aghvel Niazi (1); Anonymous Poster (1); Crabtree (2); pnaban (1); redfred (1); SolarEagle (1); TonyS (1)
