I have been looking up the potential of calcium chloride as the desiccant for fruit drying. The idea is to dry it up to a good dryness and let it suck out the moisture from the plums or apple slices or whatever at room temperature. Reason for this is because last year we had a really dry autumn and the fallen plums were turning to prunes on the ground. Molds were not growing on them and the insects were not going after them either. So I put some on a frame to dry slowly and over a month they dried to prunes with a "winey flavour". But some over dried and some dried too fast and got a bit too hot, which did not improve their flavour one little bit. Solar fruit driers depend on having enough sun but maybe if you were drying calcium chloride all summer in solar cookers, no drier would be needed? Especially with late fruit in October when typically we get no direct sunlight here at all. BUT I don't know the vapour pressure required to dry fruit (presumably I would need a little fan to speed the transfer of moisture in an enclosed system to the calcium chloride too). So, does anybody know the vapour pressure needed to dry fruit and the vapour pressures over the various forms of calcium chloride? (Calcium chloride crystals can have 2 or more molecule of water bound to them depending on its form and each form has a different vapour pressure.) Also, calcium chloride will absorb enough moisture from the air to become a solution in the moisture. Could I have a tube at the bottom and just take the salty water away as it is formed? And therefore maintain the drying until the very end. Thanks Brian white. Like maybe a big barrel of calcium chloride and you just pipe the air in and back out to the fruit to dry it. And drip the water out of the bottom of the barrel to be recharged to Dry Calcium Chloride again.
