Previous in Forum: Websites for VFD   Next in Forum: Magnetic/Short Circuit Trip Setting for 200 kW Induction Motor
24 comments
Excessive Motor Load Factor In Freezer Space
10/06/2014 12:40 PM
Hello,
I am working on a project to install VFDs on freezer evaporator units and have run into a situation where i have a calculated motor load factor over 300%! I am wondering if anyone might give me some ideas on how this is (or isnt) possible.
Some background info on the application:
The evaporator unit consists of a bank of 4 fans all on the same circuit. Each fan has a 0.5 HP motor. We are looking to install (1) VFD to control all (4) motors simultaneously. The temperature of the freezer space (where the fan motors are located) is about -5 degrees Fahrenheit (-20 Celsius).
My calculation process is summarized below:
I logged the amperage draw for two weeks at a sample rate of once every five minutes. I then calculated average amperage draw (obviously excluding any times the amperage draw was zero).
I then performed the load factor calculations as follows:
  • Voltage = 480 V
  • Assumed Power Factor = 0.9
  • Average Amps when on (A) = 9.37
  • Average Load (kW)= (Average Amps)*(RMS Voltage)*(Power Factor)*(3^0.5)/1000 = 6.99
  • Theoretical load - 6 motors @ 0.5 HP (kW) = 6*0.5*0.746 = 2.238
  • Load Factor = Average Load / Theoretical Load = 6.99/2.238 = 312%
Discussion:I spoke with the OEM and they confirmed the HP of the motors is indeed 0.5. I was informed that the fan motors will draw more amperage the colder they are. My question is whether or not it is possible for these motors to be drawing this much more amperage. If not, any ideas on what is going on here? Any help would be greatly appreciated.
Thanks for reading!
Re: Excessive Motor Load Factor In Freezer Space
10/06/2014 12:53 PM
Look-up (1) copper-resistance change vs. temperature and (2) motor "cooling' (heat-dissipation) vs. temperature...should account for much of what you're seeing.
10/06/2014 3:46 PM
Thank you. I will take a look into these issues
10/06/2014 3:35 PM
a VFD o .5 hp? are you kidding?
10/06/2014 3:44 PM
I am not kidding (Not a very funny joke had i been either). A single VFD controlling a bank of (4) 0.5 HP motors.
10/06/2014 3:40 PM
I am unsure of how to edit a post so I am just replying to my own post. The calculation should be as follows (i accidentally referenced a separate spreadsheet that was calculating savings for a different evaporator):
  • Voltage = 480 V
  • Average Amps when on (A) = 4.76
  • Average Load (kW)= (Average Amps)*(RMS Voltage)*(Power Factor)*(3^0.5)/1000 = 3.55
  • Theoretical load - 4 motors @ 0.5 HP (kW) = 4*0.5*0.746 = 1.492
  • Load Factor = Average Load / Theoretical Load = 3.55/1.492 = 238%
10/06/2014 7:54 PM
10/06/2014 3:55 PM
if speed control is the goal I'd switch to DC motorshttp://www.weg.net/ca/Products-Services/Drives/Payback-VFD-Calculator
New Zealand - Member - Kiwi
Good Answers: 29
10/06/2014 4:12 PM
You do have thermal overloads on each of the motors, don't you?
If not, your motors have no protection against overload.
paulusgnome
10/08/2014 9:07 AM
I understand the concept of having overload and short circuit protection when controlling multiple motors on a single VFD. Thank you though
10/06/2014 5:57 PM
I always thought that electrical resistance went down with temperature....anyway starting these motors with a VFD will provide a gradual startup with low amp draw...Your equation seems to be starting all 4 motors on high speed....
http://www.automation.com/library/articles-white-papers/motor-drives-control/vfds-can-control-multiple-motors
http://www.ke2therm.com/files/W-2-1_More_Fans_or_Fewer.pdf
10/06/2014 11:08 PM
I am not sure but I think the VFD is thinking it is looking at almost a dead short.
The VFD is going to calculate for six motors in parallel not series.
R Total = 1 / 1/R1 + 1/R2....etc.
For fire safety and motor protection you should use 1 VFD per motor. If speed
isn't a factor take a look at a fractional HP soft start such as Saftronics.
10/07/2014 12:48 AM
Please verify if the individual motors have thermal overload protection. (Small motors like this often do, but it is not a given.) What is the nameplate FLA on these?
Compared to room temperature air, cold air imposes a greater load on the motors. However, the cold air also cools the motor better than warm air. The second factor often outweighs the first, so that a 0.5hp motor can produce, say, 0.65hp. This may entail larger wiring and overcurrent devices, allow higher overload settings, etc.
Each installation needs specific study, with full information on components and temperatures.
10/07/2014 3:32 AM
Where you have checked the current ( at motor terminal or supply end )
10/08/2014 8:58 AM
We installed the data logger at the disconnect located at the MCC panel (maybe up to a few hundred feet from the evaporator). I am confident there are no other equipment on this circuit.
10/09/2014 5:44 AM
So the location of current measured is after VFD . Then calculation based on supply voltage may lead to wrong results on the load calculations.You should have taken the voltage prevailed at the location of current measurement for power calculations
Good Answers: 137
10/09/2014 7:11 AM
No, currently there is no VFD installed - see #19.
Belgium - Member - New Member
Good Answers: 21
10/07/2014 6:25 AM
  • Your electrical input power equals to Pin = U x I x sqrt (3) x Power factor = 480 x 4.76 x 1.73 x 0.9 = 3557 Watt.
  • Your mechanical output power for 4 motors equals to P out = 4 x 0.5 x 746 = 1492 Watt
  • Your efficiency is Pout / Pin = 1492/3557 = 42%
This means
  • a) you have very low efficiency motors
  • b) your motor has a larger mechanical loaded than the presumed 0.5 Hp. This is possible if the wind flow rate is much higher then it should be.
    • Are all the air ducts closed? (no false draught ?)
    • Can the fans work in serie? (the more flow rate, the more energy : P x V = m x R x T)
  • c) your current measurement is not correct. The current that takes a VFD is not a sinus wave, it can only be measured with a True RMS Amp meter
Good Answers: 137
10/07/2014 6:59 AM
I think you've got it there.
Also 0.9 power factor is high for a 0.5 HP motor, my data says PF 0.7 and efficiency ~ 65%. Using that PF gives calculated efficiency 54%, not that far short of published figure. The difference could be covered by the other points you made.
10/08/2014 1:39 PM
I hope these help. Resistance in parallel loads is critical to a VFD. You will
still have to solve the problem of getting the VFD to function properly.
NEC Multiple Motor Load Calculations
Motor Load Factors
Good Answers: 804
10/08/2014 2:14 PM
When measuring the input current to the VFD, which is the only valid external measurement here, you do NOT factor in the motor power factor, because the VFD is correcting it to .95 or better as far as the line source is concerned. This means that the amp draw on the INPUT of the VFD will be INCLUSIVE of the reactive current being used inside of the motors, making it read higher than what you would calculate on the OUTPUT side based on shaft loading. The Full Load Amps of a 460V 1/2HP motor is 1.1A at the most, likely less. If you have 4 motors, each drawing 1.1A, and each running at a .8PF, the input current to the VFD would be higher than 4.97A total; 4.4 / .8 = 5.5A total, meaning your motors are not even fully loaded. So there is that.
Also, if you are using a cheap multimeter to read the input current the accuracy is immediately suspect, because the cheaper the meter, the more it is going to be affected by harmonics, and the VFD creates a significant amount of harmonics. If you were reading the VFD amp output however, that's different.
10/08/2014 2:32 PM
I don't believe i was clear on my description of the problem. There is currently no VFD installed on the fan motors. I am trying to measure baseline operating conditions of the motors so that i may estimate the energy savings once a VFD is installed.
10/08/2014 3:27 PM
Hi Max,
Maybe I can help a little more.
1. Copy all of the 4 or 6 motor name plate information. Each load could be slightly different, but probably not if you are just dealing with a fan motor.
2. Are these single or three phase motors? Are the compressors part of the fan circuit?
3. It is always a good practice to use Full Load Amps off the motor nameplate when calculating loads.
4. I seem to remember we used a recorder over a ten day period to get the best baseline demand readings. This should help smooth out voltage and temperature changes. Fluke makes a perfect high accuracy meter for this purpose.
5. There is several blogs on the Internet where others have used 1 VFD for multi-motor systems. You might invest some time in reading them.
Applying VFD's to Industrial Refrigeration
Hope this helps.
10/09/2014 8:28 AM
Hi Keith,
1. I unfortunately do not have nameplate data. I have serial numbers of the equipment, contacted the OEM, and they confirmed the HP of the motors (at 0.5). I am experiencing the same excessive load factor problem on (3) different evaporators all logged independently (and with three different current transformers too!) and all on their own separate circuit.
2. These are three phase motors. The compressor is not part of the circuit.
3. Again, i do not have the name plate data.
4. I logged the motors for (2) full weeks.
5. I am confident that i will be able to control all the motors with (1) VFD. I have already done research into this and talked with a VFD manufacturer (Danfoss).
Thanks!
10/09/2014 10:52 AM
I spoke with another engineer from the OEM and they said that motors will draw significantly higher amperage when in cold temperatures (-10F). The load factors of 180%-250% did not surprise him. He said that we would need to oversize the VFD to account for the higher amperage draw.
Thanks to all who commented!
Register to Reply 24 comments
70AARCuda (1); Codemaster (2); Fredski (2); JRaef (1); KeithMorin (3); MaxT (8); panneerselvam (2); Paulusgnome (1); rudy.leurs (1); SolarEagle (2); Tornado (1)
