Previous in Forum: LNG Spherical Tank   Next in Forum: ASME B31.3 Process Piping
Small Electric Motor for Spray Injector
10/06/2014 1:29 PM
Hello I am manufacturing a new appliance and I am in need of a small motor not run by battery but electricity. This would not be the main motor for the unit it will be just to run a spray injector for the unit. Just like the Airwick scents I wish to incorporate the spray as past of my unit. I took apart the airwick mechanism. It is such a simple a motor with 3 gears and it runs by motion mine will run by a timer. When the time comes the motor runs the gears to hit the spray top and squirts a mist. That is all I need.
Would you be able to make me a mechanism such as the one I described or can you recommend someone who can. It is a very simple mechanism. Thank you.
Liz Howell
Re: Owner/ president
10/06/2014 1:38 PM
10/06/2014 1:45 PM
Go to the main page, and under "Products & Suppliers" you will find many sources.
CR4 is a discussion group, under the IHS main heading.
Publishing e-mail addresses is prohibited and not a good practice. Spam bots and malware bots love fresh fodder for their machines.
10/06/2014 2:01 PM
Is this an aroma dispenser for your alarm clock?
Good Answers: 151
10/06/2014 2:01 PM
Questions:
Is the spray container pressurized like an aerosol can? In that case you could use a simple solenoid actuator to release the spray. Or do you require some sort of a pump? What are you using for a controller? Power source voltage and current ?
What is the volume of the spray per cycle?
10/06/2014 3:39 PM
what kind of timer are you using? mechanical, solid state?
10/06/2014 5:03 PM
Re: Small Electric Motor for Spray Injector
10/07/2014 12:58 AM
why don't you use a solenoid actuator (no need of gears or cam just connect that to timer and arrange spring to return the solenoid thats it .
love4everyone
Register to Reply 7 comments
Doorman (1); Fredski (1); gringogreg (1); lyn (1); sohail0110 (1); SolarEagle (2)
