Previous in Forum: Difference Between ATM (Gage) and PSIG   Next in Forum: Mechanical Type Non Electronic Rotor Balancing Machine
NDT for Expansion Joint/Bellows
10/09/2014 5:02 AM
Instead of performing DPT is there any specialize NDT that can detect cracks on expansion joint convolution part? Especially for expansion joint attached to the heat exchanger.
Good Answers: 26
Re: NDT for expansion joint/bellows
10/09/2014 8:41 AM
Is the material ferrous? If so then Mag particle.
10/09/2014 9:19 AM
X-rays?
Good moaning!
Good Answers: 26
10/09/2014 9:44 AM
Problem is if you are more than 5 degrees off the center-line of a crack using x ray , it is unlikely to be able to detect a crack. As bellows are a constantly changing angle it would yield very little. If the cracks are all in the same area and not random orientated then an ultrasonic surface wave around 5 Mhz would work.
10/09/2014 10:24 AM
I'm glad that's in the open.
Good moaning!
Good Answers: 34
10/09/2014 10:58 AM
More than UT, PT, RT you can use:
1.-Halogen Leak examination
2.-Mass spectometer examination
3.- Air Jet Examination
Try to find "Standards of the expansion joints manufactures Association"
EJMA_7ED
http://www.ejma.org/EJMAStandards.htm
WP
Good Answers: 203
Re: NDT for Expansion Joint/Bellows
10/09/2014 11:16 PM
Blue dye, a dentist's mirror, a magnifying glass and a light. Apply the dye to the surfaces, let the dye dry and look for anomalies of the dye on the surface. This method is used for finding cracks in glass lined reactors. It is also used on some metals to find holes, cracks and surface irregularities.
Good Answers: 32
10/10/2014 11:01 AM
Seal the ends, apply air pressure to inside and coat the outside with soapy water and watch for bubbles, just like checking for gas leaks on gas piping.
Spinco
Register to Reply 7 comments
Crabtree (2); old salt (1); Spinco (1); texasron (2); Whitephone (1)
