Previous in Forum: Measuring Cone   Next in Forum: EN-13445-Cold Spun Seamless Head Change to Welded Head with 100% X-ray
12 comments
800 kVa Caterpillar Natural Gas Generator Unstable Frequency
10/11/2014 1:01 PM
dear all,
could any body give me some idea on why our 800 kva caterpillar gas engine 3500 speed is unstable with no load(1600 rpm to 1300 rpm)frequency(46HZ-54HZ)problem started when we stop it for oil change.
history,
acuator replaced by new one
carbuerator replaced by new one
linkage checked ok
magento replaced
trubo charger cheked ok
2301A speed control woodwoard replaced
magentic pick up checked ok
alteronic box replaced
gas regulator checked ok
I wish anyone of our members can help us with his ideas and solutions.
thanks
Re: 800 kVa caterpillar Natural Gas Generator Unstable Frequency
10/11/2014 2:02 PM
Does the "problem" persist when significant load is applied?
10/11/2014 2:04 PM
I think some bad spells have been cast on this generator.
10/11/2014 5:14 PM
Yes. Caterpillar can. Get on the phone and talk it through with them.
Good moaning!
Re: 800 kVa Caterpillar Natural Gas Generator Unstable Frequency
10/12/2014 8:21 AM
Can you relate the problem to cold or hot lubricating oil at startup?
If you fail to follow through, you will fail.
10/12/2014 11:19 AM
It could be an air leak. Carburetor bolts may not be tightened down properly or intake manifold bolts. Did the problem exist before the carburetor was changed?
10/12/2014 11:47 AM
Hi Standardsguy,
thanks for your response,the problem exist before carburetor was changed.
10/12/2014 11:57 AM
Wrong oil filter used, restricting oil flow? Too much oil put in? Bad PVC valve? Was air cleaner changed when oil was changed?
10/12/2014 12:16 PM
Hi,
Yes,air cleaner was changed.Sometimes speed becomes stable for short time and back to unstable situation
Good Answers: 181
10/12/2014 3:58 PM
Duplicate thread.
10/13/2014 3:04 PM
Why are you running it at the speeds you listed?
It's either 50 or 60 hz. Which one is it?
Does it stabilize when a load is applied?
"Never mistake intelligence for wisdom"
10/13/2014 6:12 PM
The oil in the actuator sometimes need to be flushed and could lead to some instability. As a result the 2301 may have been adjusted to compensate. When the oil was changed, some instability may be introduced and led to a replacement of the actuator and the 2301. We just to tune the new 2301.
01/18/2015 2:29 PM
Binding linkage
Register to Reply 12 comments
Anonymous Poster (1); Catmandu (1); Crabtree (1); diegoavaj (1); JONE (2); otha (1); StandardsGuy (2); TonyS (1); Tornado (1); Trini (1)
