Previous in Forum: bk   Next in Forum: Automobile Demobilizer
Soft Starters for a Textile Dryer
07/05/2007 3:46 AM
We have a relaxed textile dryer with four 40 KW 380-440voltsmotors which drive the belt driven blower. We have our own natural gas based electricity generation the problem is the starting torque the motors are two speed motors. I wanted to install soft-starters to prevent the starting current inrush current as it affects the generator. I have 2 200 ampere and 2 240 ampere soft-starters. Is there an issue if I use these over capacity soft-starters as their capacity is much more that 40KW.
Pathfinder Tags: soft starter
Good Answers: 54
Re: soft starter
07/05/2007 4:45 AM
I haven't any experience with excessive oversizing of soft-starters. Best is to get a product engineer help you determine if that's possible. Hopefully the rep would be more concerned with helping you rather than just getting you to buy another unit .
That said, in theory it will function. However, most soft-starters I know have current-limiting limits, meaning, their current-limit settings have a certain range based on their power rating. It's very possible that your existing soft-starter's current-limits are way, way over your 40kW motor's full-load-current (FLA).
Since your aim is to limit the starting current of your motor, your soft-starter will probably not be able to do it since its lowest current-limit setting would be much higher than what you need.
Good Answers: 804
Re: soft starter
07/05/2007 6:58 PM
He's right. Most soft starters with current limit capability are either fixed (in the case of an older analog starter) or if digital, can only be adjusted down to a certain point, usually no more than 50% of their max. rating. So if you have 200A soft starter it might be able to be adjusted down to 100A, but that is still more than the 75A that a 380V motor would draw. Even so however, if you want to use them anyway because you already own them, you might be able to forgo the current limiting capability and just use them as a voltage ramping device only. That will indirectly limit the current by stretching out the ramp time, but you can run in to a limit on the amount of acceleration time you have on the motor before the overload relay trips. Just be aware though, some soft starters do not do straight voltage ramping.
You will also need to be aware of the overload protection capability of the soft starters, because they too may not turn down low enough to protect your small motors. That will mean external OL relays as well.
Hobbies - CNC - New Member Hobbies - Musician - New Member
Re: Soft Starters for a Textile Dryer
07/06/2007 3:11 AM
Gas driven internal combustion engines to replace the electric motors might be a solution
Think and move like an electron
Register to Reply 3 comments
JRaef (1); madness (1); Vulcan (1)
