Previous in Forum: Pneumatic Leak Test   Next in Forum: A Cheap Way to Balance a Turntable
Mechanical Engineering
10/19/2014 1:13 AM
Please let me know how to choose the correct v belts and sections and no of belts for power transmission from motor pulley and machine pulley for various machine shaft revolution (RPM ) Example for 60 hp motor 1440 RPM 415 volts 50 hz 3 phase Load 60 kilogram and required machine shaft RPM 5000 . Shaft dia 70 mm. Let me know the basic formulae or calculation method for finding suitable motor pulley and machine pulley with belts sizes .
Re: Mechanical engineering
10/19/2014 1:16 AM
Re: Mechanical Engineering
10/19/2014 10:48 PM
Call your belt supplier.
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
10/19/2014 11:07 PM
Get your mechanisms textbook out. It has all the information you need. Or ask your professor.
Speak softly and carry a big stick.
10/20/2014 12:29 AM
https--www.myodesie.com-index.php-wiki-index-returnEntry-id-3065
follow this link this will give you the required ingredient to design the belt
10/20/2014 3:16 AM
The most important operational and maintenance issue in a V-belt drive is its tension. Ifbelts are too loose, they tend to vibrate, wear rapidly, and waste energy through slippage.If belts are overtightened, they will show excessive wear. An increased belt load mayshorten bearing life through excessive lateral loading and could possibly result in shaftfailure. The proper tension of a V-belt is the lowest tension at which the belt will not slipat peak-load conditions. After the break-in period, belt tension should be checked every3 to 6 months.A notched belt has grooves or notches that run perpendicular to the belt's length, whichreduces the bending resistance of the belt. Notched belts can use the same pulleys ascross-section standard V-belts. They run cooler, last longer, and are about 2% moreefficient than standard V-belts.Synchronous belts (also called cogged, timing, positive-drive, or high-torque drivebelts) are toothed and require the installation of mating grooved sprockets. These beltsoperate with a consistent efficiency of 98% and maintain their efficiency over a wideload range.2 In contrast, V-belts have a sharp reduction in efficiency at high torque dueto increased slippage. Synchronous belts require minimal maintenance and retensioning,operate in wet and oily environments, and run slip-free. However, synchronous belts arenoisier than V-belts, less suited for use on shock-loaded applications, and transfer morevibration due to their stiffness.
Example Energy
Example Energy Savings Calculations
A continuously operating, 100-horsepower (hp), supply-air fan operates at an average
motor load of 75% while consuming 527,000 kilowatt-hours (kWh) of electrical energy
annually. What are the annual energy and dollar savings if a 95% efficient (η1) V-belt is
replaced with a 98% efficient (η2) synchronous belt? Electricity is priced at $0.08/kWh.
Energy Savings = Annual Energy Use x (1 - η1/η2 )
= 527,000 kWh/year x (1 - 95/98) = 16,130 kWh/year
Annual Cost Savings = 16,130 kWh x $0.08/kWh = $1,290
Suggested Actions
■■ Conduct a survey of belt-driven
equipment. Gather application and operating-hour data. Then
determine the cost effectiveness
of replacing existing V-belts with
notched belts or synchronous
belts and sprockets.
■■ Consider synchronous belts for all new installations; the price
premium is minimal due to the
avoidance of conventional
pulley costs.
■■ Consider having a power
transmission specialist determine
the energy and cost savings
potential from retrofitting all
V-belt drives with synchronous
belts. Synchronous belts rely on
tooth grip instead of friction to
efficiently transfer power and
provide a constant speed ratio.
■■ Install notched belts where the
retrofit of a synchronous belt is
not cost effective.
Energy Tips: MOTOR SYSTEMS Motor Systems Tip Sheet #5
Mirza M Saleem
Engineering Manager
TransAsia Refinery
Karachi
10/20/2014 11:57 AM
Dear Mr.Krishh209,
V Belt Selection - Pl. refer the following Links, and you will be finding answer for your points. In addition it will educate you a lot.
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=3&cad=rja&uact=8&ved=0CCYQFjAC&url=http%3A%2F%2Fwww05.abb.com%2Fglobal%2Fscot%2Fscot342.nsf%2Fveritydisplay%2F05e93b46d277a5d785257b44006d0769%2F%24file%2FMS4050_MS4050-710.pdf&ei=gMhEVOCgI4yIuASsl4KoBg&usg=AFQjCNG1BAfHsXfW_74XqJ-bHQsCzxEIcA
http://www.engineersedge.com/belt_design/belt_design_4.htm
http://www.engineersedge.com/vee_flat_belt_menu.shtml
http://en.wikipedia.org/wiki/Belt_ (mechanical)
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=4&cad=rja&uact=8&ved=0CCsQFjAD&url=http%3A%2F%2Fwww.alexandris.bg%2Fimages%2Fproducts%2Fvb.pdf&ei=x8VEVKXsIseIuwSmpIKQCw&usg=AFQjCNF_hZ_CmcY0khH8XEICppnGGDLlIg
http://www.practicalmachinist.com/vb/general/how-size-v-belts-vs-hp-149275
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=11&cad=rja&uact=8&ved=0CBsQFjAAOAo&url=http%3A%2F%2Fwww.emersonindustrial.com%2Fen-US%2Fdocumentcenter%2FPowerTransmissionSolutions%2FCatalog%2FForm_8972E.pdf&ei=R8ZEVOPqJ9aPuATGoIKYAQ&usg=AFQjCNF_Q8jiVpAKV4_JW0QWIHib7C_sCg
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=22&cad=rja&uact=8&ved=0CCAQFjABOBQ&url=http%3A%2F%2Fwww.fptgroup.com%2Fdss%2Fdocs%2F682_03_Fenner_Friction_Belts.pdf&ei=usZEVIiZJI3guQSytoDwDQ&usg=AFQjCNFa47QL6rivZlfNyYuHxNbIL3ZuCw
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=21&cad=rja&uact=8&ved=0CBsQFjAAOBQ&url=http%3A%2F%2Fpic-designcatalog.com%2FImages%2Fpdfcat%2Fsection_5.pdf&ei=usZEVIiZJI3guQSytoDwDQ&usg=AFQjCNEHlWVq4dETf-Hz8ToCRtw2gVXlfQ
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=12&cad=rja&uact=8&ved=0CCAQFjABOAo&url=http%3A%2F%2Fwww.emersonindustrial.com%2Fen-US%2Fdocumentcenter%2FPowerTransmissionSolutions%2FCatalog%2FForm_8932E.pdf&ei=R8ZEVOPqJ9aPuATGoIKYAQ&usg=AFQjCNHCOIrPjie2n1-LUIJ7zxBUDT6wbQ
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=93&cad=rja&uact=8&ved=0CCYQFjACOFo&url=http%3A%2F%2Fwww.greenpartstore.com%2Fassets%2Fimages%2Fguides%2F2014%2FBeltGuide.pdf&ei=MCJFVL-MGZKRuASKmoGYBg&usg=AFQjCNEtgXPfhO7Y7mhwLxhs7FCABL3bfg
V-Belt Drive Design
http://cr4.globalspec.com/search/sitesearch?do=show&srchobjs=t%2Cc&order=asc&fs=14&sort=textmatchrank&query=v%20belt%20selection
DHAYANANDHAN.S
Register to Reply 6 comments
cspal3 (1); dhayanandhan (1); lyn (1); mirza m saleem (1); Oraka (1); standarded (1)
