Hi,
We have just purchased a 40W CO2 laser, for engraving metal components. A dye is painted over the area to be engraved to increase dept of marking. It also can be used to cut up to 15 mm thick materials like plastics or wood.
Do you know if there is any kind of dye we can use to increase temperature at the point where the beam gets in contact with the surface in order to solder thin metal pieces (stainless steel) together?
