Previous in Forum: CO2 Laser Dye Question   Next in Forum: Like minds?
Easy PC temperature monitoring system
07/05/2007 6:48 AM
I would like to set up a network of sensors and switches in my home, linked to my PC by bluetooth links. Mainly temperatures and current. I would like to log the data with this software too, as well as do calculations based on the data and log that conditioning of the data. Does anyone know of a vendor for such software and sensors? I understand Bluetooth can pair with over 10 remote devices normally.
Re: Easy PC temperature monitoring system
07/05/2007 6:58 AM
John: 11, 35.
07/06/2007 1:57 AM
Loolk into:
SpeedFan 4.32
Copyright 2000-2007 by Alfredo Milani Comparetti
http://www.almico.com/speedfan.php
What is SpeedFan
SpeedFan is a freeware program that monitors voltages, fan speeds and temperatures in computers with hardware monitor chips. SpeedFan can even access S.M.A.R.T. info for those hard disks that support this feature and show hard disk temperatures too, if supported. SpeedFan supports SCSI disks too. SpeedFan can even change the FSB on some hardware (but this should be considered a bonus feature). At the lowest level, SpeedFan is a hardware monitor software that can access digital temperature sensors, but its main feature is that it can change fan speeds (depending on the capabilities of your sensor chip and your hardware) according to the temperatures inside your pc, thus reducing noise. Several sensors, like Winbond's and the AS99127F support fan speed changing, as well as others from Maxim, Myson, Analog Devices, National Semiconductor and ITE, but the hardware manufacturer must have connected the relevant pins to some additional, yet trivial, circuitry. This means that if you have, say, a Winbond W83782D on a BP6 then you're ok, but not every motherboard with such a hardware monitor chip will be able to change fan speeds. From one of the very first hardware monitor chips that could be found in standard PCs, the National Semiconductor LM75 (and all of its clones, like the Philips NE1617 and the Philips NE1618 or the Maxim MAX1617) or the Analog Devices ADM1021, such chips have been greatly improved, both in their precision and in their capabilities. Current chips can monitor fan speeds, voltages and change fan speeds by using PWMs (Pulse Width Modulation). Some chips can even be programmed to vary fan speeds without any additional software intervention. If your BIOS was programmed to setup such chips this way you can still try to use SpeedFan's Advanced Configuration to revert to manual (software controlled) mode. Winbond W83697HF, Analog Devices ADT7463, SMSC EMC6D102, ITE IT8712F, National LM85C and Maxim MAX6650 are very good candidates. Some SuperIO chips include temperature sensors too. SpeedFan can automatically detect them and use their features. SpeedFan can find almost any hardware monitor chip connected to the 2-wire SMBus (System Management Bus, a subset of the I2C BUS) Serial Interface and to the ISA BUS and works fine with Windows 9x, ME, NT, 2000, 2003 and Windows XP. It works with Windows 64 bit too. It can be minimized to the tray and is compatible with Motherboard Monitor 5. Disclaimer
Ok! I guess I should write a few lines here. This program is aimed at the power user. For the ones that know what they're doing. I've known of no real problem caused by SpeedFan, but may be it's due to the fact that once it made the PC explode and the user disappeared in the blast, thus being unable to report :-) Anyway: SpeedFan can be extremely useful, but you should first watch its behavior before setting and forgetting it. How it does its job
SpeedFan monitors temperatures, through available hardware monitor chips which expose their temperature sensors connected to different places inside your computer, and, according to your setup, does its best to keep them at your desired value. You can even change a fan speed according to the temperature of your hard disk. When choosing parameters for the minimum and maximum fan speed, try to set them by hand (disable all the VARIATE FANs checkboxes) and listen to the noise. When you hear no noise from the fan then you can set that value as the minimum fan speed for that fan. I suggest using 100 as the maximum value, unless you hear a lot of noise from it, in which case you might reduce the maximum speed to 95 or 90. Obviously, nothing says that you can't set 60 as your maximum value and, sometimes, I myself set it that way. Consider that when the WARNING temperature is reached, the program sets the fan speed to 100, whichever maximum speed you set. One last word should be said regarding the USE FAN x listbox. In my pc, more than one temperature changes when a fan runs faster. You can say on which fan every temperature should rely. On my system, TEMP1 and TEMP3 are both influenced by FAN1. A few numbers...
SpeedFan can:
  • handle almost any number of South Bridges
  • handle almost any number of hardware monitor chips
  • handle almost any number of temperature readings
  • handle almost any number of voltage readings
  • handle almost any number of fan speed readings
  • handle almost any number of PWMs
Notes
First of all, you have to identify which temperature sensor is which. SpeedFan strictly adheres to available datasheets for each sensor chip. Please remember that hardware monitors are chips that do have some pins (small connectors) which should be connected to some additional hardware (temperature probes, thermistors or thermocouples) in order to be able to read temperatures. Only a few hardware monitor chips do label their connectors with "CPU", "System" and the like. Most of them use labels like "Temp1", "Local" or "Remote". The hardware manufacturers connect available pins to different temperature sensors basically according to the physical placement of components on the motherboard. This means that the same chip, an ITE IT8712F, for example, might be connected to a sensor diode measuring CPU temperature on Temp2 and, on a different hardware, it might be connected on Temp1. If you have a "Local" sensor and a "Remote" labeled one, this usually means that "Local" is the temperature of the monitor chip itself and "Remote" is the temperature read from a "remote" probe. When you have properly identified which temperature sensor is which, try to lower the speed of each fan and look at reported speed and temperatures. If you do not allow SpeedFan to change any fan speed and set all the speeds too low, then SpeedFan won't be able to avoid overheating. Latest news
4.32 - added a digitally signed 64 bit driver (fully tested under Vista 64 bit)
- added full support for INTEL CORE DUO internal temperature readings
- added full support for Andigilog aSC7621
- added full support for Fintek F71882F
- added xAP support to publish temperatures and fan speeds
- improved support for Fintek F71782F
- improved support for IT8716F
- renamed temperatures readings for MAX6640
- improved compatibility with Intel D975XBX2
- reduced AD7416 and AD7417 false detections
- reduced MAX6650/6651 false detections
- improved Intel SMBus routines
Enjoy
07/06/2007 3:20 AM
If you drop the requirement to do it wirelessly: what about Pico
http://www.picotech.com/data.html
07/06/2007 5:59 AM
Easy, go to your Cole-Parmer catalogue, or, ColeParmer.com, or, call them at, 1-800-323-4340.
Other science supply houses might also help.
07/06/2007 7:12 PM
Try this site Wolfie:
http://www.microdaq.com/
Have fun and make the world a better place.
Anonymous Poster (1); Haajee (1); PWSlack (1); Randall (1); TheEnergyGuy (1)
