Previous in Forum: Plastic Spray vs Anodizing   Next in Forum: What Would be the Iso Thermal Annealing Cycle of 18MF5 Material Grade?
Controlled Cooling after Hot Forging Process
10/23/2014 1:34 AM
Can any one explain me about the Controlled Cooling of S25CHVS1 material grade after Hot Forging Process???
Good Answers: 109
Re: Controlled Cooling after Hot Forging Process
10/23/2014 1:49 AM
Wat are you using now?
Do you have a conveyer?
https://www.google.com/#q=controlled+cooling+after+forging
10/23/2014 2:55 AM
Am using Mesh belt conveyor with circulating fans & air blower to control the cooling rate of products
Also for Micro alloy steel what would be the loading temperature in conveyor???
Good Answers: 109
10/23/2014 4:11 AM
I would not know.
Just starting with the basics
http://en.wikipedia.org/wiki/Microalloyed_steel
http://en.wikipedia.org/wiki/Precipitation_hardening
Then there is this https://www.scribd.com/doc/14344482/Steel-Heat-Treatment
I'd look for the big companies and if they have some information on their web site.
Or try this https://www.google.com/#q=Microalloyed+steel+cooling+parameter
It should get you to certain research gates which might have the information you are looking for.
Good luck!
Register to Reply 3 comments
