Previous in Forum: Can it Produce Ozone?   Next in Forum: Controlled Cooling after Hot Forging Process
13 comments
Plastic Spray vs Anodizing
10/16/2014 8:59 AM
I purchase plastic wands (for use with vacuum machines) from a supplier in China who now says they cannot use the plastic spray process because of environmental issues (good news from China - they are are starting to implement pollution controls) and he is asking if anodizing instead would be acceptable.
I have no idea what the difference would be. My first thought is that he is asking if we would switch from plastic to metal. Any thoughts?
Re: Plastic spray vs anodizing
10/16/2014 9:45 AM
I found that plastic spraying is similar/same as powder-coating which they are now doing on the aluminum wands. I am not sure what anodizing is or what it would look like.
10/16/2014 9:49 AM
It's a chemical process similar to plating.
Google it.
It should be fine.
10/16/2014 9:56 AM
Thanks Lyn, I googled it and now I understand a little more. I am going to ask the supplier to send me a picture so I can see the difference in esthetics.
10/16/2014 9:58 AM
I added a picture to my first post.
Re: Plastic Spray vs Anodizing
10/16/2014 10:30 AM
Between plastic coating and anodized will be a big difference in feel....possible more vibration to the hand, electrostatic discharge may become a factor, and temperature, as heat transfer should be more evident....I definitely would expose this new product to a test group before implementation and see if it will effect any endorsements such as ul....cya
10/16/2014 10:59 AM
Good thoughts and questions I will convey to my supplier. I didn't think about the UL certification and if it will be affected. Thanks!
Good Answers: 92
10/16/2014 10:47 AM
The question you need to be concerned about, is why are you powder coating the tubes now? If they are currently aluminum, the powder coat will protect the metal from material being conveyed (note that it may not need protection, but plastic coating materials are generally more resistant to corrosion than metals such as aluminum) and also protect peoples hands from the grey marks you can get handling untreated aluminum.
Anodizing is not plating, but is a treatment that alters the natural aluminum oxide surface layer. It will give enhanced wear (but not chemical corrosion) protection over untreated metal, allows a wide range of custom colours including natural, and cannot flake (unlike powder coating). It also protects hands from marking.
Re: Plastic Spray VSs Anodizing
10/16/2014 11:02 AM
I am not 100% sure they are powder coated. My supplier calls it "plastic spraying" and it feels like a think plastic coating on the outside only of the aluminum wand. I am hoping this anodizing process is not more expensive.
10/16/2014 2:16 PM
Anodizing will give corrosion protection depending on how the anodized coating is sealed. Some of the coating weight/seal combinations achieve quite high salt spray results.
One more difference between powder coat and anodizing is damage protection: both to the tube and the furniture (or product conveyed, not quite sure what kind of vacuum machine we are talking about).
Powder coating is more forgiving than bare metal to damaging furniture and to showing damage to itself. Anodized surfaces are quite abrasive compared to powder coat and will damage furniture and wall corners like rubbing a file over them.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
10/16/2014 5:22 PM
The vacuum cleaner wands I have seen are entirely plastic (PVC or ABS maybe).
Good Answers: 92
10/17/2014 12:12 AM
Some of us shop at places other than Home Depot or Menards...
Seriously though, you are right for the most part. However, commercial duty (read meant for use by full time cleaning staff etc.) wands are usually aluminum, often with stainless steel fittings if meant for wet use such as with an extractor. The wands cost about as much as a shop vac.
10/17/2014 8:02 AM
These are wands for commercial dry and wet/dry vacuums.
Thanks everyone for your comments and answers!
Janice
Good Answers: 123
10/18/2014 12:32 AM
You may want to check for dimensional changes. If the plastic coating is baked on powder coating will be a lot thicker than anodizing. Any mating parts will need to match the new finished size.
Bob
Register to Reply 13 comments
bob c (1); janice smith (5); JNB (2); lyn (2); Mike W (1); SolarEagle (1); Tornado (1)
