RFG in Indiana goes stale in my car, then it won't start. I have a carburator that requires the "gas" to lift up out of the fuel bowl into the venturies and idle nozzles. (Fomoco/Autocraft/Motorcraft 2bbo). Down draft carburators are too tall.
My gas tank which I replaced with a new one in 2008 is designed for real gasoline, and is not a pressure vessel. I have put a non-vented cap on it for storage (it requires a vent for driving, I have to change it) and plugged the auxillary vent line, but the volatile part of the RFG now blows out through the needle valve into the float bowl and out the vent. I don't drive enough to keep the RFG fresh, with its full compliment of butane or whatever the volatile part is. So I'm stuck with a tank full of amyl butyl ether, and the car won't start. It starts fine when I pour laquer thinner down the venturies. It started fine in 1972 after 6 years storage on old gasoline, but they won't let me buy that anymore.
I'm seriously against electric fuel injection. I was nearly arrested in a customer car when I was a transmission mechanic and a fan belt broke on a road test. I got two miles before the battery died and the car stalled. Then the police stopped to "help" me. I've driven this 1959 car 220 miles at night with the generator light on (bad generator brushes), and 25 miles with a piece of twine as a fan belt. These modern cars are so dependent on tow trucks, a cell phone, and a fat credit card. Besides, run over a railroad tie at 60 mph or a curb at 25 with the brakes locked, in a modern car and see how much it costs you - it didn't hurt this car at all, except the dents in the wheels which I knocked out with a hammer.
I did put a nozzle in the air leaner, connected through a needle valve, pressure regulator, and solenoid valve that drips RFG into the carb throat, to get past the no-idle circuit problem. If I can get the car started, it works, then when the RFG is heated by the warm engine, I can shut the auxillary nozzle off. But later, (less butane, I suppose) the car won't start. Not for two years.
I tried to put a LPG 15 lb tank in the trunk, for starting, with a nozzle in the air cleaner, but ASCO won't sell me Vitron sealed 12 VDC solenoid valves because I am not a business. I was going to use a 1 psi loss check valve to inject the LPG into the same nozzle I'm using for the idle RFG circuit.
I'm not installing a LPG tank in without a solenoid NC valve BEFORE the rubber diaphagm regulator, in case of an accident. I saw a motor home burned down to the motor wheels and axles on I40 in 2012, with a lot of high school kids in athleltic trophy jackets standing around looking lost. You know motor homes can have a dual LPG tank auto switchover device involving two rubber regulators with the tank valves open at all times? This motor home hadn't even been in a two vehicle accident as far as I could see. I did find LPG tank to pipe thread adapters, and bought one, but am stuck at the shut off valve part.
Alternatively I have put a NEMA C laminate spacer under the carb and put electric heaters in it. I originally put eight 68 ohm three watt resistors and four 62 ohm in there. This started the car with the nozzle drip on, which ran for one second. I had noticed, for the first five miles my car always got 5 mpg, which for short household trips was all I got. I suppose it was only burning the volatile (butane) part of the RFG. On 50 minutes to my country property I was getting 17 mpg at the end, a record milage for this 4000 safety cage.
On the theory that the heaters ae not hot enough, I put 4 watt 39 ohm resistors, (ceramic fireproof Vishay) twelve of them under the carburato. I got the car to start and run three seconds before something made me shut it off. These resistors are going to need a voltage regulator to 11 VDC if I power them after the alternator is charging to 14 vdc, which complication annoys me.
I did put a 11 ga steel plate under the spacer with 1/8" holes in it, in case a backfire shatters a resistor case, to keep big ceramic shards from getting in the cylinders.
So far I'm still riding a bicycle everywhere. Fuel injected cars are not an option, I would drive maybe 1000 miles per year and the wire harnesses force the check engine light on and "limp home" mode after average 8 years, with the *****y brass and phosphor bronze connectors manufacturers use on the computers. So for a $30000 3/4 ton supercab pickup (equivalent to my 59 ranch wagon in carrying capacity) I could get 8 trouble free years for only $4 a mile. My brother sold off a 2006 Ford pickup in 2012 with only 90000 miles on it, because nobody could repair it where the check engine light would stay off. The 2008 Chevrolet I bought the wife had a check engine event at 33000 miles and 37 months on a 36 month warrenty, where the temperatur reading was reporting "------* because the thermostat was off. The heater was working fine and the car wasn't boiling over, how are you supposed to know the temperature is off value if the ***-**** computer won't let you see what the temperature is? And the code was "temperature sensor failure" which was a big lie.
Imported cars are not an option; I need a manufacturing job and those ******a production workers never bought anything made in Southern Indiana in their lives.
I've thought of something really wild, and electric pressure vessel with catalyst that converts diesel fuel to methane-ethane-propane-butane right under the hood, but I'm afraid that sort of experiment is a bit beyond my skill. Besides, the vendors probably won't sell anything to me because I am not a business. I'm lucky mcmaster.com wll sell me things, at one point newark.com would not, until debit cards and the internet were invented.
BTW, the buna-n solenoid valve I bought from mcmaster for the RFG drip at idle system lasted two weeks before RFG dissolved the rubber (I presume) and it stuck closed. Terrible stuff, RFG. I did get one vitron sealed solenoid valve out of the old ASCO distributor in my territory, but the new distributor won't answer my e-mails or phone calls, and the factory rep told me I have to buy from them, or not at all. Skinner stainless valves are $110 each, and nobody stocks 12 VDC or vitron seals in those, either.
So what would you do? I'm making fenders for my bicycle this week, since everything you buy for a consumer is made in a country that is beating up on the Phillipines tourist industry this week; it was Japan they were boycotting last month. My heart and lungs are in great shape as a result, but you can't carry home cement or plywood for building projects, or a piano for your country estate, on a bicycle. I could rent a truck, but I'd like to start and drive my car.
