Chef owner ran utilizing metal boxes to their water meters sealed
Wong Nai bang, ran to query the master to use out of your water, were suspected to become property in "tricks"
February 7 meter water consumption tons; four March meter water consumption; April four ton meter water consumption;
May possibly 21 ton meter water consumption; June meter 34 tons of water consumption; July 26 show about 10 tons of water
This is the master ran water in recent months, in Might or June, the sudden surge of water that ran a single more issue inside the life from the master--"defend the meter."
Might 21, June, 34 tons. He suspects the house stealing water meter readers, right after welding sealed iron box, water about ten tons a month. Ran teacher wonder, why does water prior to and after the negative so much?
Master ran Fort on Wong Nai bang gold ?? Palace district, 3-2, developing 1, lived for more than a year.
Yesterday, 9 o'clock in the morning, ran the master waiting for us at residence. His son is often a lawyer, usually reside in Fuling, usually for the city on a small business trip. The Residence was bought by his son, smaller in size, one particular sitting-room and a area and a toilet.
Son Property, also bought a roof next to a garden, an region of hundreds of square meters, ran following Baker retired from the mine in Guizhou, Chongqing City to assist in the Residence. The heat, below watering with tap water plants, clean well being.
Ran teacher man, found a job in May possibly, he was back household at night, and wash your clothes. Every single time the water charge is, not quite a few, seem around the list, four ton, 7 tonnes.
Battle for water meters "shoot" ... ...
Chef ran the huge query:
"In early June, I spent 4 days in Guizhou province, nobody at household, and as usual, only son occasionally spend the evening with out making use of a lot water. In Could or June, the climate is a lot of rain, watered the flowers will not use so much water? "
Thus, bloody battle for water meters within the air.
Noise and house theory of meter readers
Theory of property-meter reader Chen Shifu, Single-Jet Series Water Meter to no avail. Ran teacher also is paid Might 21 tons of water, "the revenue I paid, but I've an issue. ??
Posted on homemade seal press mudra
Ran the master meter box located only home is the crucial, he doubted home meter readers "fiddle stolen water", he began to take measures.
On July 3, ran working with A4 paper, spot 5 cm wide and 15 cm extended strip, vertical writing above his name, also pressed the three red ink fingerprints. Just before writing the names, he divided the names on two sides, "after the seals affixed to the meter on, which you'd like to move the table, Volumetric Piston Series Water Meter it is actually essential to eliminate seals, will my name apart. Apart and provides it away. ??
Keep the soldering iron box locked water meter
Ran the master relieved slightly, but then thought of a "brilliant idea".
On or about July six, he welded a frame of iron water meter box, need to see a meter dial. Right after the frame, having a padlock to lock, Multi-Jet Series Water Meter "and then the cheats, it is possible to only lock. ??On July 26, ran teacher also isn't assured, calling Chan master door opening the meter box, located below the meter displays the quantity 309 tons. "So from June 30 to July 26 only makes use of about ten tons of water. ??
