I have a rack and pinion mechanism that is prime moved by a hydraulic motor and has all the components like gear box, couplings and brake etc. the equipment which is moved by this is in a normally inaccessible area and operated remotely. recently an incident happened that there was mechanical failure of coupling and the total system was rendered non functional leading to a series of events involving shutdown of the equipment and incur of losses by virtue of not being operational for good amount of time. I was asked to design an emergency drive that could take up the task in case of requirement. can any one help in suggesting some idea of emergency systems that are in place elsewhere.
