Previous in Forum: A J-Box   Next in Forum: No Alternatives to Multi Piece Rims in Machinery?
36 comments
What Is It?
11/06/2014 3:36 PM
Yet another "what is it" from me where I don't have a clue what the answer is.
This was about a year ago, maybe more but I just got round to trying to figure out what I'd seen. I decided to film a dramatic hail storm through the back window. Suddenly I very clearly saw something run down from the top of the fence and along the path. I say I saw it clearly because I remember seeing it all the way from the top of the fence 'til it disappeared. Curiously the recording does not show anything until the object is near the bottom of the fence; however for reasons which I suspect will become obvious I am pretty sure that I was watching the screen of the camera rather than "real life"
The whole sequence took about a second or two.
Nothing visible
Half way between the top of the picture and the greenery far left
Just above the greenery
Half way down the greenery
This is the best close up I could get from any of the freeze frames:-
I do have one idea but I'll wait to see what other people think.
Pathfinder Tags: Hail Mystery object ufo what is it
Re: What is it
11/06/2014 4:00 PM
Was an inspection of the supposed path made, in an attempt to discover physical evidence of, and possible identification of, a creature... like tracks?
Did you also see a moose?
Re: What is it
11/06/2014 4:17 PM
No: there would have been no evidence, the hail storm was very violent.
And: No. A moose in a garden in England?? There is obviously some reference here I'm unaware of.
Got to go now. Talk to you all tomorrow.
Re: What is it
11/06/2014 4:40 PM
Moose and Squirrel will usually be seen traveling together.
Re: What is it
11/07/2014 2:31 PM
Thanks.
Re: What is it
11/06/2014 11:57 PM
You must not have much hail there! I don't think of a hail storm as violent unless the hail stones are approaching golf-ball size. I have seen hail stones that were 100mm in diameter, out on the plains of Colorado.
Re: What is it
11/07/2014 2:36 PM
Only a handful a year, and, rarely as bad as this one was.
Re: What is it
11/06/2014 4:19 PM
It's a bug on the lens....
Re: What is it
11/07/2014 2:46 PM
My best guess was a pollen grain on the lens, but, I think RedFred has it at #4.
Re: What is it
11/06/2014 4:19 PM
My WAG is that this anomaly is an out of focus water drop on the glass of the window. The brown color is the brown fence in the background.
Re: What is it
11/06/2014 11:46 PM
I think you've got it!
If you study the positions of the fence posts etc., you can verify that the camera WAS moving sideways. A water droplet on the glass will effectively be a plano-convex lens with a very short focal length, akin to a fish-eye lens, but not focused, so you see a blurry image of (mostly) a large amount of fence through the droplet.
The droplet appears to be moving from left to right, so the camera was actually moving from right to left.
Re: What is it
11/07/2014 2:58 PM
I think so too, but, I think that the main cause of the movement was probably the wind blowing the droplet along the window rather than the camera moving (I cut all the pictures above out of a much larger image, so I don't think it's possible to accurately judge the movement of the camera). But I could easily be wrong.
Re: What is it
11/07/2014 2:49 PM
GA
Good Answers: 266
Re: What is it
11/06/2014 4:30 PM
A bird. Flying thru the images.
Re: What is it
11/07/2014 3:01 PM
I don't think so: I think I would have definitely seen it "in real life".
Re: What is it
11/06/2014 4:54 PM
A year ago, Autumn? a fallen leaf blowing in the wind?
Regards JD.
Re: What is it
11/07/2014 3:03 PM
Don't think so: a leaf would have been hammered to the ground by the hail.
Good Answers: 97
Re: What is it
11/06/2014 5:33 PM
Could it be a Hail Mary?
What the hail is it?
CRTL-Z
Re: What is it
11/07/2014 3:12 PM
Good Answers: 97
Re: What is it
11/07/2014 3:36 PM
HAW!
CRTL-Z
Good Answers: 114
Re: What is it
11/06/2014 5:37 PM
How many frames per second? I suspect that it wasn't one single object, it was a series of hailstones falling close to the window.
Re: What is it
11/07/2014 3:28 PM
This is embarrassing: I haven't a clue. I took the video on my Archos 50 Platinum, and I can't find a spec. for the frame rate anywhere.
Otherwise no the playback definitely shows a single "object" moving smoothly across the screen.
Re: What is it
11/06/2014 7:36 PM
My guess is water (out of focus) on the glass between you and the storm. If you closely look at the second frame, you will also see a brown smudge at the RHS middle of greenery that can also be followed in the later frames.
The one that caught your eye was probably a water film that developed into a single drop and was then blown sideways across the window. (Presuming prevailing wind from Left to right.)
Later in the sequence of frames, there is another (third) smudge that develops almost centre of frame.
I guess that the item of interest developed in the wind shadow of the window frame (the reason it was able to form a drop that blew sideways) while the others are in the wind zone and are being flattened.
Re: What is it
11/07/2014 3:30 PM
GA
Re: What is it
11/07/2014 8:38 PM
I agree. The falling hail shows as a streak indicating that the wind was blowing in direction you surmised. GA
Re: What is it
11/07/2014 9:41 PM
I'm not so sure! In the second frame, the hail streak is very nearly vertical, perhaps a bit to the left as it falls. By the fifth frame, the hail is clearly moving down and to the right, so the wind above the house was clearly changing.
Of course the wind can and will swirl all sorts of ways around houses, fences, window frames, etc. So the direction the wind blows on a given point on the window can be quite different for that of the wind that gave the hail its direction of fall.
Presumably, the camera was pretty close to the window, to get a better view outside. In that case a very small motion of the camera past the window would produce a rapid motion of anything on the window. As I indicated in a previous post, my best guess (and it's no more than that) is that the drop was essentially at rest on the window as the camera moved past it.
Re: What is it
11/09/2014 5:14 AM
Yes I saw that too. But you will also see that the assumed drop is moving down vertically for the frames 1,2,3. and then goes across to the right as the falling hail goes to the right. To my mind this seems to be a confirming consistency. Randall did say that these are enlarged stills from a sequence taken from a movie where the camera was held still. This would tend to support the argument that the drop was being moved, not the camera. The direction of the hail streaks gives a hint as to what the wind MAY have been doing. Any way I am enjoying this exercise as it is not just hair splitting but also a good exercise in forensic hypothesis.
Re: What is it
11/06/2014 9:15 PM
Its an invisible shapeshifter that got cought out by the hail and your camera.
You do believe in aliens, don't you?
Re: What is it
11/07/2014 3:33 PM
Either way it's incredible! ↓ ↓ ↓ ↓ ↓ ↓
Good Answers: 203
Re: What is it
11/06/2014 10:17 PM
Either of:
1. water on the window that causes it to be blurry since it is out of focus vs. the fence. As the camera or the water drop moves the mystery item appears to move.
2. A brown gremlin vs. the green type doing handstands to confuse you as it tries to steal your leaves off the ivy.
3. Too much Jameson's.
4. Too many pints of Dab
5. The lens needs cleaned,
Good Luck, Old Salt
Re: What is it
11/07/2014 3:36 PM
1. Yes
I'll go for the Jameson's tonight.
Good Answers: 26
Re: What is it
11/06/2014 10:26 PM
Obviously, the Spring-Heeled Jack has been caught on video for the first time. Never mind the absence of the blue and white flames and the eyes like balls of Hell's fire. It's likely these where suppressed by the hail storm. Did the camera's audio happen to pick up laughter?
He's a lot smaller that I thought he would be. Based on the reports in the late 1800's I figured he would be the size of a man.You just can't trust eye-witness testimonies. People let their imagination run wild sometimes, I suppose.
Good Answers: 21
Re: What is it
11/07/2014 2:37 AM
A bit early for the Easter Wabbit...
Re: What is it
11/07/2014 8:03 AM
Did somebody Feed GIZMO again?!!?
Good Answers: 69
Re: What Is It?
11/07/2014 12:00 PM
We should be able to attach MP3s, but for now here you go:
Good Answers: 97
Re: What Is It?
11/07/2014 12:13 PM
Do you have a McDonalds nearby? It may have been dislodged from the grill vent fan during the storm.
CRTL-Z
Re: What Is It?
11/07/2014 3:46 PM
Barchetta, Hilton, corbinstein, Unredundant:- Stranger things have happened.
Yahlasit:- Sorry, I'm too stupid my education isn't good enough for me to read music.
Register to Reply 36 comments
Barchetta (1); corbinstein (1); dkwarner (3); Doorman (2); Hilton (1); IdeaSmith (1); jdretired (1); JIMRAT (2); Just an Engineer (1); old salt (1); ozzb (1); passingtongreen (1); Randall (14); redfred (1); SolarEagle (1); Unredundant (3); Yahlasit (1)
