Previous in Forum: Regarding 50N/51N Relay   Next in Forum: A.C. or Variable Voltage or Something Else?
11 comments
Fence Grounding
11/07/2014 10:42 PM
we have section of wooden fence between metal fences at HV substation fence due to isolation purpose. As per code is it possible to install metal barb wire on top of wooden fence without connecting with metal fence' barbwire. Any suggestion is appreciated.
Re: Fence Grounding
11/07/2014 11:14 PM
"As per code", means that someone must know the codes. Do you? Apparently not.
You keep asking the same lame questions about grounding.
My code book says don't ground. I'll approve the request. Just send it on the back of a $100.00 USD bill. I'll copy it, with approval stamp, and return it to you.
Re: Fence Grounding
11/08/2014 8:13 AM
Is your code referring to barbwire atop a wooden fence in general, or specifically for HV substations?
Roughly said, usually in substations you ground everything which can be grounded (e.g. all metallic door frames in and outdoor) and there are very good reasons to do so. There are detailed grounding schemes to follow.
And what does you lightning protection expert say?
Good Answers: 225
Re: Fence Grounding
11/08/2014 11:15 PM
I think that i would be grounding it if only to remove any induced voltages from the mix.
Re: Fence Grounding
11/08/2014 11:27 PM
follow electrical code (NEC)
Re: Fence Grounding
11/09/2014 5:17 AM
The prospect of a decision-maker at an HV installation who is unaware of the content of the local electrical code I find somewhat worrying.
Good moaning!
Re: Fence Grounding
11/09/2014 6:27 AM
It certainly is possible.
  1. Look at your design drawings.
  2. Check with your consultant.
  3. Read the Scope of Works
  4. Look at your BoM.
  5. Use non conductive barbed wire.
  6. Use insulators.
  7. Read the Code again.
  8. Change jobs.
  9. Don't energise the sub.
  10. Ask you PM.
  11. Ask an electrician.
Re: Fence Grounding
11/09/2014 7:07 AM
if you cook must you know the recipies, or refere to the cook book if not fameliar whick kind of foood you want to cook with.
electrical code, experience eletrician they are good companion when doing such electrical works.
Re: Fence Grounding
11/11/2014 2:02 AM
I do not understand why you want to install a barbed wire over wooden fence.Is it to prevent some one climbing over it? any way you can but ground the barbed wire fence .It can be connected to the same earth .
United States - Member - VT
Re: Fence Grounding
11/12/2014 9:01 AM
If using vertical boards, cut the top ends with a saw to make points. After boards are mounted, use a 1 1/2" hole saw and put the pilot at the vertex where boards meet. Result will be uncomfortable to climb over, non-conductive, and decorative. Use non-conductive stain or paint.
If fence is existing, mount a row of broken bottles along the top. An opportunity for a little creative artistry in an otherwise humdrum industrial environment...
Teach your cat to write
Re: Fence Grounding
11/13/2014 9:49 PM
In here, our regulation required all metal material around the substation need to be earthed as to prevent induction generated from the substation. But I think it a good practices to earth all metal material to ground.
Good Answers: 109
Re: Fence Grounding
04/20/2015 12:56 AM
Its a barbed wire to fend off intruders. I'd say leave it ungrounded.
Register to Reply 11 comments
Apol (2); Crabtree (1); IdeaSmith (1); IQ (1); jonaparker (1); lyn (1); nesubra (1); Plimos (1); Simon Wan (1); spades (1)
