Previous in Forum: MATLAB to ATP/EMTP   Next in Forum: Electrical Troubleshooting
Electronics (Microcontroller)
11/08/2014 12:23 PM
Why in micro controller 8051 ((ATMEGA89C51) pull up resistors are not connected internally at port 0? While there are internally built resistors to other ports?
Pathfinder Tags: microcontroller
Re: Electronics (Microcontroller)
11/08/2014 4:11 PM
I believe you will find your answer by looking at how a zero becomes a one on port 0.
11/09/2014 10:41 PM
Port 0 is an 8-bit open-drain bi-directional I/O port. As an output port, each pin can sink eight TTL inputs. When 1s are written to port 0 pins, the pins can be used as high- impedance inputs.
Port 0 may also be configured to be the multiplexed low-order address/data bus during accesses to external program and data memory. In this mode P0 has internal pullups.
Port 0 also receives the code bytes during Flash programming, and outputs the code bytes during program verification. External pullups are required during program verification.
Atmel Datasheet
The best vision is insight - Malcolm Forbes
Register to Reply 2 comments
