Previous in Forum: Advantages & Limitations for Using Ceramic Lining in Pipes   Next in Forum: Graphene Filtering Your Water?
Lime, Pac, Polymer Usage of Textile Waste Water
11/12/2014 3:58 AM
Right now we are using lime, pac, poly for textile water treatment. Our treatment system is sbc then batch type aeration system.now we are facing problem in secodary treatment ie aeration system. Our sbc system cod reduction are around 40-45 % but in aeration system only 20-30 % of cod reduction. How to improve cod reduction in batch wise aeration system.
Anonymous Poster #2
Re: Lime, Pac, Polymer Usage of Textile Waste Water
11/12/2014 4:49 AM
Use more fish hooks.
Reply Score 1 for Off Topic
11/12/2014 7:10 AM
You need a specialist in-house to investigate. If you haven't got one, hire one.
Good moaning!
11/12/2014 8:26 AM
Get a bmoc system and use 75% bmf to up the cod to match your sbc.
Or, blow harder.
11/12/2014 3:56 PM
Probably goes back to the original design of the system.
Has the throughput gone beyond design level? Are there additional COD loads beyond the original design brief? etc.
There might be methods to increase transfer (blow harder, smaller bubbles, longer residence time etc.) that will help your outcome.
Need a professional expert to assess.
Might even need to review whether addition of "bugs" into the system would help.
11/20/2014 3:33 PM
Maybe you should have done a study on the biotoxicity of the C.O.D. including whatever new chemical(s) you introduced, that stunted the population of aerobic organisms! Go back the the beginning, and hire a competent consultant who can manage the newly formulated problem into a complete answer with results!
Anonymous Poster (1); Crabtree (1); James Stewart (1); Just an Engineer (1); lyn (1)
