Previous in Forum: Designing the Steam Power Plant Parts   Next in Forum: Transmission Temperature Sensor
Pipe Support Crevice Corrosion
11/13/2014 9:53 AM
Are your pipe supports giving you headaches, how to inspect them, repair the piping and have a lasting solution?
Lift-Off pipe supports have a lasting effect on crevice corrosion mitigation. These pipe supports have been specifically designed to drain trapped liquid under the pipe.
These supports raise the line approximately 1/2" and can be installed without any hot work.
Ideally suited for hard to maintain and inspect areas and range from 1" to 72" lines and weigh much less than conventional supports.
Lift-Off supports are ideally suited for uninsulated lines, can be used where line shoes have fallen off the support steelwork.
For more information, please go to our website: www.liftoffpipe.com
CR4 Admin - Removed Phone Number
Re: Pipe Support Crevice Corrosion
11/13/2014 11:21 AM
Spam : Reported
11/13/2014 10:15 PM
I'd like a sample of the supports for:
1",2",3",4",5",6" and all the rest through 64". I don't work on big pipe.
I also need supports for short pipe, long pipe, curved pipe, uphill, downhill, and flat land pipe. Flanged pipe in all sizes, too.
Pre-rusted, if available. That will save us some time, on-site, applying the rust.
Send it to my summer home in upper BFE. FOB, of course.
ASAP, AIW.
11/14/2014 9:54 AM
Thank you for your enquiry, we can discuss on line.
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
You can also see a demo on Facebook.
Good Answers: 26
11/14/2014 10:46 AM
Are your pipe supports giving you headachesOnly when i don't wear a hard hat and i hit my head on the supports.
Good Answers: 70
11/14/2014 10:42 PM
Maybe my eyes are deceiving me, but I think I still see surface contact between the pipe and support. And the last time I checked, thats where corrosion grows, between surface contacts. And if you have enough liquid draining off your pipes that you need to a special channel, then you have more problems than just corrosion.
11/14/2014 11:56 PM
I can't help those that can't see, for they will always live in the dark.
Good Answers: 70
11/15/2014 12:34 AM
I'll tell you what I do see and that is snake oil.
Register to Reply 7 comments
dj95401 (2); JPool (1); lyn (1); martinschutte (2); texasron (1)
