Dear Friends,
I have a requirement wherein I have to calculate the pipe thickness for 30 year life service. I think that the ASME B31.1 formula is valid only for 25 year design life. (Please correct me in case I am wrong). So,I plan to calculate as per normal way of ASME B31.1 and then use the TRD-301 life calculation of pipe ( which calculates life considering fatigue due to the operation cycles ) to check if the same can survive for 30 years.
Will this be a correct method ?
The RLA is given in ASME also, but it is related to corrosion. I want life calculation base on fatigue. Is there any clause in ASME where the life calculation can be done ?
Thanking you in anticipation ,
Regards,
