Previous in Forum: Wall Thickness Calculation for 30 Year Service Life   Next in Forum: Circular Key Stress Concentration Factor
Combining Wind and Solar to 24/7 Power Blog
11/26/2014 12:39 PM
Recently saw an article: http://www.sciencedaily.com/videos/7bdf3c8319a5ffeae565a710fea6ea74.htm
about how an Israeli firm is storing solar thermal plant energy to generate steam 24/7. I think is this excellent, since energy loss of the system is <5% by storage.
Why not do the same with wind energy? Here is a crazy idea for a wind turbine that could be added to the type of solar energy storage without anything greatly fancy.
1) all the mechanical parts of the wind turbine are there, except the generator, and subtitute a 90 degree gear box. Install a giant brake hub on the output shaft with various (spring?) pressure to generate heat from the rotor motion.
2) Heat must be removed, so the back part of the brake (stationary part) is cooled with thermal storage fluid (not molten salt), with some control auxilliaries to (a) allow hub to turn when wind is present AND thermal fluid flow is taking place, and (b) start up the thermal fluid when the wind starts up.
3) Heat needs to be stored in the thermal fluid reservoir system (for later use), or sent directly to heat recovery steam generator
4) As in the pure solar example, steam powers the turbine-generator set.
My question for the discussion: What materials will work the best for the friction system, and can anyone project a life for such a system compared to existing equipment? Another related question is there any advantage at all to doing this from an efficiency standpoint (I think not), but could there be a real advantage to grid stability from having some fraction of a wind power facility operate in this mode?
Re: Combining wind and solar to 24/7 power blog
11/26/2014 2:00 PM
Mr. Stewart:
Why not use wind generated electricity to heat the thermal storage medium?
And why Thermal Storage? Perhaps only where geography or available water prohibits gravitational storage? Or perhaps because latent heat storage can reduce required volumes?
Given huge water management issues why not focus on hydro storage when possible; where the upper and lower reservoirs can be used for water management purposes?
Could hydro storage architecture use cleaned waste water for aquaculture and irrigation as well?
Grid integrated small unit production and storage greatly reduces the technical challenges of solar and wind energy production and storage. It also makes the macro system much more robust.
Perhaps the greatest problem with renewable energy and storage is the architecture of scaled centralized power production.
I still don't understand all of the pushback from the big players. If the margin between the grid sale price and small unit producer supply price were great enough then the ROI should be as good as centralized production. The distribution of Grid integrated Small Unit Power Production could be made to be as profitable for the big grid players as well as more physically efficient; both being a must for adaptation.
When scaled to point of use overall grid stabilization as well as storage become less problematic.
Imagine the implications of small scale production.
Imagine what happens to when railroad capacity is freed up for alternative products other than coal .
Imagine what happens to economic growth when energy costs go down.
Imagine what happens to consumer product demand when the bottom 98 percent have more discretionary income.
12/01/2014 2:38 PM
The simple reason I suggested a direct frictional heating is that there is a well-known conversion of mechanical energy to heat that is 100% efficient every time. The question would be coupling of this frictional heat with another thermal storage fluid sufficient in heat transfer and maximum temperature properties to safely store high temperature (high grade) heat. Then, when the "renewables" production lags demand, the stored heat is routed to steam generation, etc.
I could see the off-grid types liking this because it is basically very simple to implement. They might have to be careful not to wear out the friction plates, or to friction weld them together! The idea is the home owner would store the heat in whatever convenient system can be placed on his property safely. Then when he needs power, he would activate thermal recovery, steam generation, and power turbine, until done. Nothing hazardous, except heat and steam, and electricity.
11/26/2014 4:17 PM
I read on this several weeks ago, I still don't know what this mystery "cement like" fluid is or its BTU/lbs characteristics are but It sounds promising. just as all renew-ables generation isn't the trick, storage is
12/01/2014 2:10 PM
I gave everyone a GA! I agree that every answer is a "good" answer when it comes to storing up energy. I ran across a local company that is making energy storage from renewables even as attactive as a liquid fuel. Ammonia can be combusted in IC engines with extra high compression (and NH3 is a smooth-burning fuel with high "octane" rating).
The company offers hydrolysis of water (new efficient design to be sure), separation of air, combination of hydrogen and nitrogen in high compression, high temperature reactor (catalyzed), with energy recovery, and liquid anhydrous ammonia as the product. They even have a new engine design linear piston engine with linear coil and generator that (1) starts the engine, (2) accelerates the compression of air intake, and (3) generates direct electric power on the power stroke. Valve system is unique from my perspective. They also offer a module to produce solid fertilizers for agricultural use. The system is very clean burning, and requires no oil (advanced materials robust enough, and ammonia combustion leaves no deposits). Ammonia is commonly stored in carbon steel pressure vessels, and it is not a problem when the normal safety precautions are taken. Not only that, there is an interesting connection with blending ammonia to gasoline or diesel, and it works too.
Re: Combining Wind and Solar to 24/7 Power Blog
11/26/2014 10:49 PM
Storage of energy could be in many ways. As static head of water, as thermal, well insulated salt or steam, as chemical energy, as in a storage battery.
We have to see the advantages of various possibilities. Battery is the most useful one, with portability, ease of recall. Static head of water would require a large inundatable area, and as heat, perhaps most ideal for large scale.
One has to choose the best.
Fredski (1); Gadepalli Subrahmanyam (1); Gavilan (1); James Stewart (2)
