Previous in Forum: Hydrogen Analyzers for Hydrogen Generation Plant   Next in Forum: Magnetic Flow Meter
Integral Manifold
11/28/2014 6:57 AM
Can any pls explain what is difference between Integral manifold and a manifold with test port?
Re: Integral Manifold
11/28/2014 7:27 AM
Yes. The equipment manufacturer can, over the telephone.
Good moaning!
11/28/2014 7:48 AM
Got it.. i think crabs dont get technical things..
Reply Off Topic (Score 3)
12/02/2014 2:44 AM
If we're stooping as low as opinions, then I think that Anonymous Poster #1 is socially inept, and frightened to use the telephone.
Good moaning!
11/28/2014 8:48 AM
Here is a Google tip, if you start a Google search with the command define: you will get a definition of the word or common phrase that follows the command.
11/28/2014 11:53 AM
They aren't necessarily different.
Good Answers: 176
11/28/2014 4:16 PM
With only minimal description, I'll assume you're talking about instrumentation 3 or 5 valve manifold valves which I suspect some marketing guy calls "Integral Manifold".
A 3 valve manifold can easily isolate the transmitter from the process for installation or removal from the process and for a zero check. 3 valve manifolds might or might not have vent ports where each port has a needle valve, but 3 valve manifold always lacks the large T handle valves which make it easy to apply a test or calibration pressure. They only have 3 T handles, not 5 T handles.
A 5 valve manifold has two additional large T handle vent valves tied to vent ports which can be used to either vent pressure from the blocked off transmitter or to apply a test or calibration pressure.
Crabtree (2); Iris (1); Kruti (1); redfred (1); Tornado (1)
