Previous in Forum: Electromagnetic Flow Meter Installation Issue   Next in Forum: Air Flow Validation in Large Size Ducts
Magnetic Flow
12/02/2014 7:44 AM
Dear All,
Would like to carry out loop check for the magnetic flow meter
promag any testing equipment to simulate
please advise thank you.
Re: Magnetic Flow
12/02/2014 12:06 PM
You ought to be talking directly to the manufacturer on this if, indeed, the information didn't arrive with the equipment.
What is it these days? Is the world frightened to use the telephone, the quickest route to the information?
Good moaning!
Good Answers: 176
Re: Magnetic Flow
12/02/2014 2:19 PM
See my answer to your earlier question on the same topic.
http://cr4.globalspec.com/thread/98482/Magnetic-Flow-Meter
Re: Magnetic Flow
12/05/2014 4:46 PM
Okay - you've worded it a bit different each time you ask. One time it appears as though you are trying to simulate the sensor signal to a remote transmitter, the next it sounds like you simply want to check the transmitter 4-20ma signal to whatever is receiving it. (an analog input card in a PLC?)
The 4-20ma is easy as dozens of loop checkers are available out there to simulate a 4-20ma signal. (Altek makes a good one - 334A)
The sensor signal is another beasty all together, that I've never tried to simulate. The manufacturer will have to help on that issue.
Crabtree (1); Iris (1); Phys (1)
